| Equipment & Tools From test equipment to hand tools |
#51 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#52 |
Nah, you saved me from wasting my time, thanks so much. Could you please point me to an opamp based notch filter schematic which is not sensitive to well matched RC values? The 100k nasties I can fix.
#53 | |
Cordell Audio: Papers: Build a THD Analyzer If you just want a precise notch circuit which is insensitive to component values, I don't have a clue
#54 |
A good notch filter is also sensitive to layout, not just component values!
Texas Instruments has a filter utility which is free to download "FilterPro" -- it will allow you to see the effects of using "exact" values, and resistors from E12 to E192, caps E6 to E24. I'll say this 'til I'm blue in the face -- the HP3581 has one of the best filter systems you're ever going to see for audio -- I just picked up another HP3581 for $49 a few weeks ago. It's RMS detector is better than any unit you'll find in a hand-held DVM. Of course, unless you're Hercules you're not going to hand-hold a '3581! |
#55 | ||
#56 |
HP3581A has bandwidth filters of 300,100,30,10 and 3 Hz -- and they have skirts like a crystal filter should. You have to use a slow sweep with the lowest bw xtal filter. The HP3581 can be "automated" if you have a sweep generator and data-acquisition card.
#57 |
Oh, but not a notch filter to null the fundamental. Perhaps you're saying use the band filter to isolate and measure individually the 2nd, then 3rd, etc. harmonics? But I could do the same with the hp 3585a, simply choose the start and stop frequency around the harmonic number(s) that I want to measure. Then the dynamic range would apply only to those harmonics. Or am I delusional here?
#58 |
Hello,
After some advice of Ghg, i have build a twin-T notch filter at 10kHz, to try to measure the THD of the ultra-pure oscillator from the AN67 of Linear Tech. For that, i use a small shielded box with 0.1% metal resistors and 1nF 1% low drift mica capacitors.After the passive notch filter, i add an OPA134 low THD OPAMP as follower. Is it powered with clean linear +/-12DC supply. I used Spectraplus for plot the filter response in frequency domain. As you can see in this first file : 10k_NotchFilter.pdf , the notch filter allow approximately -68dB attenuation at 10kHz. This performance is very good for non trimmed filter. Then, i make a measurement of oscillator spectrum with this notch filter inserted between the oscillator and the ADC. For this purpose, i use my old ADC (AKM AK5394 IC). You can see the resulting spectrum here : THDwithNotch.pdf The THD (not THD+N!) measured by Spectraplus is 0.035% ! Only the second and third harmonic are visible, at levels of -155 and -160dBFS (here 0dBFS is 7.07Vrms or 20Vpp). In green on the same plot, you can see also the notch filter response. To calculate the real THD, you must add some gain for the harmonics, corresponding to the notch response. The notch filter attenuate H2 to about 9dB, H3 about 5dB and H4 about 3dB. The input level at of the signal at notch filter input is -14dBFS, so attenuation at 10kHz is about 68dB. After correction of the level of harmonics, and correction of the level of fundamental, the recalculated THD is about 0.000039%. It is corresponding to -168dBFS ! To be sure that the ADC doesn't introduce THD at this input level, i have also build a -70dB passive attenuator. I have inserted this attenuator between oscillator and ADC, and was made same spectrum measurement (With this attenuator, the ADC input level become same as notch filter, but all harmonics are attenuated by 70dB). The resulting spectrum is THDwith70dBAtt_lin.pdf show clearly no harmonics contain. This allow to say that previous THD measurement with notch filter is valid. I really think that it will be extremely difficult to build better oscillator than that ! Frex. Note: I have send files (including Gerber,bom,schematics..) to DIYaudio user for building this oscillator. I think that if many people are interested to build it it could be a good idea to make a group buy for the PCB. The price of it can be very low if 10 or more is ordered. Please let me your opinion.. |
#59 | |
![]() The best I've been able to do is about 0.0025% with a simple circuit from Elektor. |
#60 |
I'd also be interested in the pcb. How difficult do you think it would be to make the oscillator 1kHz, if possible at all?
| need an analog-to-digital converter schematic | prorms | Digital Source | 0 | 28th March 2008 08:29 PM |
| Digital to Analog Converter DAC With Cable | mg16 | Swap Meet | 1 | 11th September 2006 06:27 AM |
| Analog to Digital converter | amirmk | Digital Source | 9 | 26th November 2005 12:50 PM |
| Differences between Digital and Analog Audio | oscarcasalini | Digital Source | 1 | 7th January 2004 11:32 PM |
| Digital to Analog converter | condor655 | Digital Source | 4 | 15th May 2003 10:02 PM |
