| Equipment & Tools From test equipment to hand tools |
#171 |
Hello Frex, Where can I read more about this project? This DAC looks very versatile! How did you implement the USB connectivity? Thanks, Mike |
#172 |
Hello,
Unfortunatly, the web site that i had started to design some month ago is not yet ready and i don't have described this project on DIYaudio. Probably because many DAC design has already designed and described on DIYaudio ! But yes, this DAC is very versatile. The USB input use the very common PCM2906 that allow only 16bit/44-48kHz operation, but the internal DACs are dual PCM1792A in mono mode with fully differential operation. Optical and coax input can handle 24bits/192kHz. The DAC can be controlled (digital volume and mute) with any RC5 compatible remote control. If you are interested by the project, i have some bare PCBs of this design that i can sale. Of course, all design files will be provided. If many DIYers ask me, i could also strat a dedicated thread. HERE, you can read the full schematics. Regards. The PCB view : The internal view: ![]() FRex
DIY CS5381 ADC / DIY 10kHz Super Oscillator / DIY DC-1MHz RMS-DC converter & 60dB LNA . |
| need an analog-to-digital converter schematic | prorms | Digital Source | 0 | 28th March 2008 08:29 PM |
| Digital to Analog Converter DAC With Cable | mg16 | Swap Meet | 1 | 11th September 2006 06:27 AM |
| Analog to Digital converter | amirmk | Digital Source | 9 | 26th November 2005 12:50 PM |
| Differences between Digital and Analog Audio | oscarcasalini | Digital Source | 1 | 7th January 2004 11:32 PM |
| Digital to Analog converter | condor655 | Digital Source | 4 | 15th May 2003 10:02 PM |
| Page generated in 0.07755 seconds (68.64% PHP - 31.36% MySQL) with 12 queries |
