| Equipment & Tools From test equipment to hand tools |
#11 |
If I were going to do this I'd try to take the fastest route, even if it cost a few bucks more. First, I'd buy a Measurement Computing USB-1208FS for about $189. That gets me analog input, analog output and a bunch of control lines. I'd build a PCB for the DUT so I could power it and read the voltage and current. I'd also have a choice of driving the base/gate with both current and voltage sources. Finally, I'd write a nice Windows control program in PowerBASIC to talk to the Measurement Computing unit. Right now my ancient Tek unit (yes, tubes) takes care of things, so I don't need a DIY project, but FWIW I've done all the separate pieces described above for various different projects and it seems a sensible path.
Conrad
I used to be an audiophool like you but then I took an arrow to the knee. |
#12 | |
I can dream, can't I? |
#13 |
I bought yesterday the Heathkit IT-1121 and I hope it will work good
Stefano |
#14 |
Does it work?
The response of the inner ear extends to at least 200khz - Dr W. Tempest |
#15 |
Here you can read from a another forum about Circuit Ed I found
Perhaps little old info: mikroElektronika • View topic - Semiconductor Curve Tracer Developed with EP3 and mikroBASIC Forum: mikroElektronika • Index page Easy Buy Page - mikroElektronika |
#16 | |
I need at least 3 to match power transistors.
| DIY Curve Tracer for PC | locky_z | Solid State | 179 | 25th May 2012 02:12 AM |
| B-H Curve Tracer | gpapag | Equipment & Tools | 9 | 16th January 2011 08:22 PM |
| curve tracer | barclaycon | Equipment & Tools | 6 | 11th February 2010 08:10 PM |
| curve tracer? | maxpou | Solid State | 4 | 24th October 2009 05:29 PM |
| Tube curve tracer project | andrei | Tubes / Valves | 17 | 18th August 2007 12:49 PM |
| Page generated in 0.09205 seconds (76.03% PHP - 23.97% MySQL) with 10 queries |
