Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 29th December 2009, 06:19 AM   #1
Send a message via MSN to gadgeteer123
Default I need a DB meter please.
Does anyone have a DB meter I can buy or trade for that can read to at least 150db??
Old 29th December 2009, 08:19 AM   #2
Mooly's Avatar
Decibels are ratios, not units
Decibel - Wikipedia, the free encyclopedia
Old 29th December 2009, 08:20 AM   #3
??- I'd just like one that can read that loud so i can test my systems at home.
Old 29th December 2009, 08:25 AM   #4
Mooly's Avatar
You mean a sound pressure meter (SPL) like these, some are quite cheap new,
Your Search Results | CPC
Anything over 95 to 100 db is "loud" for a domestic system... 150 db... that's like standing a couple of meters from a jet engine with the afterburners on... and you would be deaf
Old 29th December 2009, 08:26 AM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Are you talking about sound pressure? In which case dBA is a common ratio.
I really think you should look up the meaning and relevance of your question:
Sound pressure - Wikipedia, the free encyclopedia
Or in simpler terms:
About Decibels (dB)
Then think about the value you have asked for...
Old 29th December 2009, 08:26 AM   #6
Mooly's Avatar
Look at these examples,
Old 29th December 2009, 08:32 AM   #7
I am talking about the db rating they use in SPL competitions, and my stereo can hit 140-145db so thats why i need it to go atleast that loud.
Old 29th December 2009, 08:41 AM   #8
Mooly's Avatar
Originally Posted by gadgeteer123 View Post
I am talking about the db rating they use in SPL cometitions, and my stereo can hit 140-145db so thats why i need it to go atleast that loud.
Pardon
Old 3rd January 2010, 03:56 PM   #9
tvrgeek is offline tvrgeek  United States
If you hit 145 dB, don't worry, you are probably half deaf already. 135 dB peaks is enough to cause irreversible damage with half an hour. ( Please refer to the OSHA site) Just because you can jump off a cliff, does not mean you need to.
I believe they use calibrated instrumentation mics at the competitions. They cost more than your stereo and car but together. But if you must, just back off a few feet using a generic cheap SPL meter and do the math.
Old 12th January 2010, 02:46 AM   #10
dangus is offline dangus  Canada
Low frequencies are much less harmful than 1 kHz. The weighting curves reflect that. Otherwise you'd be deaf from a slammed car door or swimming underwater.
Some strain gauge pressure sensors can be used as microphones up to very high SPLs. I remember reading that in a Sensym application guide. 150 dB SPL is only about 0.1 PSI. 170 dB is about 1 psi.
If you have one lying around, try the sensor from a barometer or altimeter, a MAP sensor from a car EFI system, or one salvaged from some medical instrument.
db meter speedie Equipment & Tools 2 22nd September 2009 01:55 AM
db or vu meter branet Parts 3 9th May 2009 12:14 PM
Leader LMV-1815 2 Ch Auto dB Lever Meter Mikewong Analogue Source 0 19th July 2007 07:27 AM
About DB Meter MatrixElect Swap Meet 1 12th January 2005 10:47 PM
About DB Meter MatrixElect Multi-Way 3 12th January 2005 04:54 PM
Page generated in 0.09095 seconds (86.82% PHP - 13.18% MySQL) with 10 queries
