Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 29th December 2009, 05:28 AM   #1
Default HP8903B Audio Analyzer Software
I've once again started fooling with my 8903 application. If you have an HP 8903B and a Prologix GPIB interface box, this software will automate scanning of response and THD, plus a couple other things. It will not work with any other interfaces like National. There are still a few bugs, but I use it regularly with good success. I'll try to add features and fix the bugs as time allows. No guarantee I'll take 'em, but any suggestions will certainly be considered. Program is on my software page.
The Messy Basement
Best,
Conrad
I used to be an audiophool like you but then I took an arrow to the knee.
Old 29th December 2009, 01:46 PM   #2
thud, er, bump!
Old 29th December 2009, 02:32 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by Conrad Hoffman View Post
thud, er, bump!
Hello Conrad,
Interesting application! I've bought the Prologic interface to use with my HP3577 but for lack of time, I haven't done more than just play with it a bit. What are you using for plot output? I use a software HP7440 emulator.
jd
Old 29th December 2009, 03:24 PM   #4
The application is written in PowerBASIC, somewhat similar to Visual Basic, but with features and an approach I like far better. I modded the FTDI include file slightly and it was off to the races. I do my graphics on the screen, but I wanted to take advantage of the resolution of modern printers, so I recreate everything for the printer, rather than just copying a bitmap. That's where most of my bugs are. There are things I can do with scaling on the screen that are more difficult to do for the printer, and I don't have the math quite perfect yet concerning the drawing of the log lines for every possible scan range. Everything is done through USB/GPIB, so no plotter emulator required. BTW, I think PowerBASIC is still running a sale on the previous version of the program and it's screen editor, which is nearly identical to the current version. I also fooled with communicating with my old HP3455, and it worked fine, ditto my frequency counter, but I haven't come up with a reason I'd want to. PB also works well with the Agilent IO Library Suite and I use that at work to do test programs for various LCR meters and the nice Agilent 6 1/2 digit voltmeters.
CH
Old 3rd January 2010, 04:30 PM   #5
FWIW, I'm slowly converting my old web pages from horrible MS Word generated code, to validated strict XHTML code. It may take me years to fix them all, but if you've visited the site before it's a good idea to hit refresh on the pages so you don't continue to get the old ones from your cache.
Best,
CH
Old 16th January 2010, 11:31 PM   #6
Just put up a new version, 1.45. Old bugs out, new bugs in!
CH
Old 4th February 2010, 05:11 AM   #7
New version 1.47 up, should solve a variety of issues.
CH
Old 6th February 2010, 01:35 AM   #8
tomchr is online now tomchr  United States
tomchr's Avatar
Sweet!! I've been mucking with some MATLAB scripts to do the same thing. Basically, I'd like to run sweeps of distortion vs frequency, amplitude vs frequency, and distortion vs output power for a couple of different frequencies. Currently, the version of MATLAB I'm using won't run on my PC because it isn't compatible with Windows 7 so I was looking at other options...
Does your software have the capability to store the raw data as a comma-separated file or similar?
Thanks,
Tom
Old 6th February 2010, 02:40 PM   #9
Yes, there's a button to save a CSV file. I haven't messed with that lately, but it's trivial to change exactly what and how it saves. Someone gave me a great suggestion about setting things up to arbitrarily choose what gets assigned to the x and y axes of the graph. It will be some time before I can make that major of a change, but it would allow graphing say, thd against amplitude changes. Right now I only do frequency sweeps, no amplitude. There are a few quirks listed in the readme file, and I'm gradually fixing those, but there aren't very many people using this thing, so I don't get much feedback. Where this really shines is if you service equipment for people, you can print a really nice performance curve, or set of them. It also saves a huge amount of time during circuit development.
Best,
Conrad
Old 8th February 2010, 04:57 AM   #10
Ver. 1.48 is up- printer scaling should be improved.
CH
RE instruments audio Analyzer?? Hardi Equipment & Tools 26 11th June 2011 02:02 PM
UPA audio-analyzer azaz Swap Meet 0 13th August 2007 10:00 AM
Audio analyzer software pro's/con's XEAGLEKEEPER Everything Else 1 10th January 2007 02:16 AM
audio spectrum analyzer norvbul Solid State 6 6th March 2006 01:06 AM
Audio Analyzer audioPT Everything Else 0 13th August 2003 11:12 PM
Page generated in 0.11574 seconds (77.46% PHP - 22.54% MySQL) with 10 queries
