| Equipment & Tools From test equipment to hand tools |
I added a new ultra cheap flourescent light fixture above my workbench a few days ago. It uses two T8 32W tubes.
I fired up the oscilliscope and found a horrible amount of ~45KHz noise everywhere; if I hold the scope probe up near to the light I can read 20Vpk-pk! At a distance of 4 feet to the benchtop, it is still 100mV pp. Is it possible to buy an electrically quiet flourescent fixture or is it just the nature of the beast? |
#2 |
If you can afford it, use LEDs. Halogen is another option, but it's much less efficient.
Also try adding a metal window screen over the cover and grounding it.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#4 |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Luxo lamps with incandescents...At least three for variable point sources, four is best. Trying to use flourescents for benchwork for me is all wrong. The color is unbearable, the buzzing is annoying....and as you yourself has discovered, are electrically noisy. The Eco-friendly argument is false as flourescents require more "environmental damage" to produce & dispose.
__________________________________________________ __________-Rick.... |
#7 | |
#8 | |
Maybe you can modify your lamp and use a conventional ballast? Regards |
#9 | |
It took me a moment to figure it out. Now, I turn off the the lights if I have to make delicate measurements, noise floor, etc. |
#10 | |
But there's really no reason to use regular incandescents if you don't like CFLs. Halogens offer a better spectrum, are more efficient and last longer than regular incandescent, are dimmable, and are available with built in reflectors for more focused light. I can't wait until LEDs become cheap enough for general lighting. (I know of an environmentalist (Allie Moore) who claims that she looks prettier under light from an array of "broadband white" LEDs...) If you can't wait for LEDs, what about CCFL? Find a LCD TV with a bad screen (actual LCD panel is bad to the extent it's useless but backlight is still good), take out the CCFLs and power supply, then make it into a standalone light. You can expect great spectrum since the tubes are for lighting up a high quality video display, after all.
| Bench test equipment, What's yours? | TheGimp | Tubes / Valves | 37 | 13th November 2009 11:50 PM |
| Bench test | KEEBIE | Car Audio | 4 | 1st November 2006 05:11 AM |
| Speaker Bench Test | evilorange | Multi-Way | 9 | 13th October 2005 04:30 PM |
| What Test Equipment Do You Have On Your Bench?? | ultra-lo-fi | Everything Else | 56 | 14th June 2005 03:47 PM |
| ultimate test bench | camusmuse | Everything Else | 2 | 13th September 2004 07:59 PM |
| Page generated in 0.13257 seconds (76.86% PHP - 23.14% MySQL) with 11 queries |
