| Equipment & Tools From test equipment to hand tools |
#41 |
Likewise. I use guttering lined with slightly crinkled kitchen foil as a diffuse reflector for the fluorescent.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#42 |
HI EC8010 I see you use High efficiency headphone
#43 |
Only mono, though.
Since people were complaining about the RF noise produced by HF fluorescents and she-who-must-be-obeyed wanted better lighting for her sewing machine, I thought I'd investigate a 36W HF fluorescent before screwing it to the ceiling. The first thing I looked at was the current through the tube, which turned out to be an integrated 39kHz square wave (first waveform). Then I got the 'scope to do an FFT of that waveform to see what the harmonics were like (they go up to 570kHz). Finally, I looked at the current waveform from the mains, rather messy, but approximating to a sine wave (which is more than any audio kit does).
#44 |
#45 |
Making a good living from the Timsons
#46 | |
I suppose at some loss of light, one could wrap the fixture in a wire cage to block some RF. Never tired it. The buzz would still drive me crazy. I use plain old light bulbs; you know the ones they want to ban in Europe. In the winter, they are 100% efficient as you are using all the excess heat. (I can heal Al Gore wincing) LED's are not ready for prime time. Cost too much, and the ones in the local store are not as efficient as CFL! As I am not young, I need a LOT of light. A bank of PAR-60's and no problem with noise in my system. Consider it a cost of instrumentation. I use a sheet of glass to block some of the heat. |
#47 | |
#48 | |
Actually, one would need to look at the rest of the design. Plastic lens instead of glass maybe? LED's are still under 40% efficient. Lots of heat available. Glass holds the heat and is far more massive, so it would not build up while the bulb is off. A plastic lens has such low thermal mass, it could. Just a thought. |
#49 |
Yes, I think you tend to get what you pay for. My HF fittings weren't cheap, but at least they were properly made and they don't produce as much noise as some people seem to be suffering. CCFLs draw a horrible spiky current from the mains.
| Bench test equipment, What's yours? | TheGimp | Tubes / Valves | 37 | 13th November 2009 10:50 PM |
| Bench test | KEEBIE | Car Audio | 4 | 1st November 2006 04:11 AM |
| Speaker Bench Test | evilorange | Multi-Way | 9 | 13th October 2005 03:30 PM |
| What Test Equipment Do You Have On Your Bench?? | ultra-lo-fi | Everything Else | 56 | 14th June 2005 02:47 PM |
| ultimate test bench | camusmuse | Everything Else | 2 | 13th September 2004 06:59 PM |
| Page generated in 0.12294 seconds (82.80% PHP - 17.20% MySQL) with 11 queries |
