Test & Measurement interface for Soundcard - Page 48 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 25th February 2012, 08:57 AM   #471
_Wim_ is offline _Wim_  Belgium
Originally Posted by yurgs View Post
Hey there,
i had some success using ARTA and Autdiotester, but my soundcard drivers seem to be limited to 22kHz, how can i get the card to work with more bandwidth ? its the same with the M.Audio 192 and the onboard card
Greetings from Munich
yurgs
I have no such problem with my cards. If I set sample rate to 96kHz I am able to measure up to 48kHz.
Old 25th February 2012, 09:35 AM   #472
pinkmouse's Avatar
Yurgs, mind your language.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 25th February 2012, 06:20 PM   #473
AndrewL is offline AndrewL  United Kingdom
Try setting the sample rate in the window's control panel.
-- Andrew
Old 25th February 2012, 08:23 PM   #474
-- Andrew
Thanks Wim and Andrew,
this was the right direction.
I set the sample rate in the "M-Audio" Controlpanel, but when you start the Measurement, Audiotester overwrites the settings,
Thanks again
Old 25th February 2012, 09:15 PM   #475
Thanks again
I do not know for audio tester, but for ARTA you need to set the sample rate in ARTA (and it also overwrites the settings in the control panel)
Remark: with the EMU 1212 you have to select the same sample rate in the EMU-patchMix DSP panel also, no autoselection here...
Old 26th February 2012, 07:24 AM   #476
I think you may need to fix them so they are all the same. In Audio Tester there's one menu, last one of the right, I think (don't have it handy) where you can set sample rates. I recall this being hard to get correct but not what I did.
Come to think of it, perhaps there's an order to it, open AT set it to what you want, close AT, then set window's panel to the same values, then open AT. Worth trying?
Andrew
Old 26th February 2012, 10:48 AM   #477
On Hiatus
SY's Avatar
In AT, use the drop down menus. Under "Options," you want Audio In Parameters and Audio Out Parameters.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th February 2012, 11:52 AM   #478
Yep, SY, that's the one!
Old 26th February 2012, 12:02 PM   #479
Thanks for your help!
i adjusted the sample rate in both and tried my first pc based measurements
i used arta/steps to measure the bandwidth of my own valve amp, pic attached.
the dip @ 35kHz is sometimes visible on the soundcard output as well,
Greetings
Yurgs
Old 26th February 2012, 07:43 PM   #480
kevinkr's Avatar
Hey there,
yurgs
I'm assuming you installed the proper M Audio driver. Try using the alternate sound DLL and select ASIO.. Note that I had to disable the onboard sound and uninstall its drivers on one of my boards before the 24192 would work properly and then manually install the 24192 driver. [Windows XP PRO SP3 32 bit]
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Recommendations on pc audio interface for loudspeaker measurement diypole Multi-Way 9 15th July 2009 12:45 PM
Request for advice / high performance soundcard for measurement Gordy Solid State 8 14th February 2008 04:14 PM
MCM Speaker Measurement Interface / USB Woofer Tester sdclc126 Multi-Way 0 17th January 2007 01:00 AM
Tenma Speaker Measurement Interface johngalt47 Multi-Way 1 6th January 2007 02:17 AM
Soundcard interface. Mr Evil Everything Else 5 12th July 2005 11:38 PM
Copyright 1999-2017 diyAudio
