Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 24th November 2009, 05:59 AM   #11
cliffyk is offline cliffyk  United States
cliffyk's Avatar
Hello all--newcomer here,
I just purchased a Peak ESR70 a couple weeks ago, in deference to the "blue" kit, and found this thread while searching for more info. It works quite nicely however I found the leads to be absurdly short and the supplied crocodile (alligator here in Florida) clips to be worthless for in-circuit testing.
The lead length was an easy fix, I cut the twin coax line off of a cheap set of "ear-buds" and used both the shield and center of each cable for each pole of the tester's input.
To address the in-circuit issue I made up a set of tweezers from Popsicle sticks--nothing magical in the construction, just cut the pieces/parts to fit and glue 'em up--I built up each leaf (tweeze?) with stacked pieces to provide a grip and then applied the heat-shrink tubing.
The probe tips are 1" brass escutcheon pins bent up as needed and epoxied in place--I have since bent the probe tips inward so as to grab solder pads more forcefully. In use I clip the croc's to the exposed head of the pins.
It all works well and will calibrate to 0.00Ω with no problems...
Old 27th November 2009, 01:04 AM   #12
gootee is offline gootee  United States
Good job on the tweezers!
My VU meter gev Analog Line Level 1 11th April 2007 07:21 AM
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
Page generated in 0.06272 seconds (69.59% PHP - 30.41% MySQL) with 10 queries
