Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 9th October 2009, 12:05 PM   #11
Originally Posted by dangus View Post
........... the rest isn't hard. Transformer, caps and rectifiers could come from a junked hifi receiver.
20 amps???!!! Doing that with a linear supply will be interesting... big transformer, big caps, lots of power transistors.
and what about dissipation when the output voltage is <<30Vdc?
A multi tapped transformer is virtually obligatory for a linear supply.
regards Andrew T.
Old 9th October 2009, 02:03 PM   #12
star882 is offline star882  United States
star882's Avatar
A low voltage buck converter is pretty easy to build. And no high voltages after the transformer so it is very good for beginners.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 9th October 2009, 02:08 PM   #13
I've seen some on the net but don't know if they are safe.
regards Andrew T.
Old 16th October 2009, 06:43 PM   #14
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Does it have to be the cheapest of the line?
I've been using Delta Power Supplies for years in the lab and I'm convinced they are the best... not the cheapest though....
They'll last you a lifetime... I have an oldie at home. (30V / 10A) linear jobbie. Weighs a ton, but still works beautifully after 20+ years
More Power Igor! More Power!
Old 21st October 2009, 09:35 AM   #15
DRC is offline DRC  United Kingdom
DRC's Avatar
Buy a secondhand one made by a good manufacturer. Unless you want very high power stick to linear designs.
dave
Old 22nd October 2009, 06:03 AM   #16
star882's Avatar
Start with something very low power, like step down a 9v battery to 5v or 3.3v. Such a low power circuit is very safe to handle.
Switching regulators have become much cheaper than in the past. You'll really want switching for any significant amount of power as the thermal dissipation of a linear becomes prohibitive at higher powers. In modern commercial equipment, I have seen linear only used up to about 2w or so, except LDO which is still used at higher powers as thermal dissipation is still manageable. Above that and switching is the regulator of choice. In fact, given the very low cost of switching regulator circuits, the break even point where a switcher would be cheaper is surprisingly low and continues to fall.
Note that a low voltage buck converter is only slightly more difficult to design than a linear. And it is a good learning tool for beginners. My first switcher was based on a National Semiconductor switcher-on-a-chip and I used it as my bench power supply for a few years. To give you an idea of how easy it is to build it, I built it in 5th grade. It worked perfectly the first time I turned it on.
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
CRC Power Supplies jleaman Solid State 1 12th March 2005 05:51 AM
HV power supplies santa Swap Meet 0 17th January 2005 10:52 PM
50V power supplies, qty=2 kjunom Swap Meet 0 27th December 2004 09:32 PM
Regulated Power Supplies for Low Power Amps PTL60 Solid State 18 6th February 2002 06:24 AM
Page generated in 0.09317 seconds (76.37% PHP - 23.63% MySQL) with 10 queries
