Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 14th May 2003, 08:22 AM   #1
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Default DIYAudio CNC Router
For a long time, I’ve wanted to design and build a 3 axis CNC routing machine to reduce the time building cabinets (with better results). I’ve had a few thoughts and here are some of the problems I envisage…
The 3rd axis (Vertical Z axis): I assume a motorised screw would be sufficient.
Measurement of movement: This has to be accurate but at the same time, should be irrespective of tolerances in the drive to the motor. For instance, counting the number of turns on a motor is not sufficient if the belt has stretched etc.
Cutting Through: If you are cutting all the way through the baffle (for instance) how would you not damage the router’s base?
SOFTWARE: We would need software to interpret the simple, but extensive CNC language. The programmes are 70-80 A4 pages of instructions for relatively simple shapes.
Is there any interest? Is this possible for not too much money? I would like to build it so that it could be scaled to larger or smaller work, as people require. For my application, I would want it to be 1500mm cutting distance in length and 700mm cutting distance in width. The maximum height would be 50mm.
Thanks,
Gaz
Old 14th May 2003, 09:50 AM   #2
purplepeople's Avatar
The least expensive units I've seen in Canada are about Cdn$1000 per square foot work area, so the unit you would want would be around $20K. That said, you could probably still build your own for about $6K-8K. Still no small feat.
Unfortunately, you would probably have to spend around $1500 for the CAM software (which usually comes free with the commercial units). Your choices will depend on your current CAD software. Your website shows you are using some kind of 3D modeler, so compatibility with that is your first priority when choosing CAM.
You'll need to decide whether you want to go with stepper motors or servo motors. Steppers are slower but cheaper. Servos are faster and usually don't have any position errors but are more expensive due to the more complex controllers (position feedback) required.
Other than the controller, I'm guessing that the single most expensive components will be the linear bearings and the ball-screws needed for such a big work table.
I'll bet you've already decided on whether you want your machine to be 2-1/2 axis or a full 3-axis. For most panel work, 3-axis units are probably not needed, but it could make for some interesting 3D surfaces.
One thing about cutting through work pieces. It is always good policy to have a throwaway layer mounted to the machine work table. That way, any mistakes usually won't drill their way into the machine but only the throwaway layer. It's also good practice to add the extra layer, then machine it's surface down flat using the router. That way, your Z-axis is always referenced to a consistent altitude.
Sounds like fun. Good luck. I'll check back when I return to work as I have a number of links there from some research I did when our department bought a small unit.
:)ensen.
Old 14th May 2003, 10:20 AM   #3
Rarkov's Avatar
Thanks for the reply. At the moment, I use 3D Studio MAX and then export to AutoCAD 2002...There must be plugins available, if not I could write one...Maybe!
I have assumed I would use Stepper motors with a severly down geared drive to get good resolution. I do not know much about Servo motors. I do not believe that this project would cost anything like that amount...I'm sure it could be done for under £1000 (about $1500)
I do not intend for the router to be able to change it's "angle of attack" on the work piece. Just XY movements and up and down. Is this 2-1/2 movement?
I suppose I'm not looking for amazing accuracy, just better than I could do with a line and a jigsaw!
That's a great idea for a throwaway layer...as always, I was making things more complicated than they really needed to be.
I have had another idea for the software. About 3 years ago I made a custom protocol and programme that would create instructions for a router using a black and white image, this was for a PCB CNC machine I was planning on building. I could convert this to do the same job, cutting out a huge cost. I could also make it quite specific to speaker building.
Thanks,
Gaz
Old 14th May 2003, 11:15 AM   #4
diyAudio Moderator Emeritus
jean-paul's Avatar
www.nc-step.de Just built the electronics for an uncle. He bought it there with all the steppers and metalwork. It is offered as a kit without casing for the electronics.
It's only audio
Old 14th May 2003, 11:26 AM   #5
jean-paul's Avatar
This is what you get concerning electronics. The boards are CNCed of course. Looks very good and I am curious about the results of the machine. Bearings and steppers are very high industrial quality material. The steppers are Vexta C8872-9212K or Teco L2108. Everthing was shipped with datasheets and a good manual. Maybe I can make some PCB's with it
It's only audio
Old 14th May 2003, 01:22 PM   #6
Circlotron's Avatar
Do a search for DANCAD 3D. It is CNC shareware and has LOADS of info about building a machine and just about anything else you would need to know.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 14th May 2003, 02:47 PM   #7
jackinnj's Avatar
Default CNC Newsgroups
there are two CNC Newsgroups on Yahoo --
with respect to measurements -- as I understand it you basically set your zero, move a set distance, measure, move "set" back to zero and measure the "backlash" -- the software does the rest.
Old 14th May 2003, 03:07 PM   #8
Rarkov's Avatar
Thanks for all this info. I have decided on the following:
Static bed. All movement is handled on the "bridge" that moves up and down the long bed. I think this is more suited to tall thin speaker panels that I make.
Attempt to build this for a standard router. Routers have four screws underneath their bases. It's be nice to interface any router to this and enable the user to calibrate the machine per session (or routing bit).
I am still not sure how to fix the wood to the bed without interupting the edges. For instance, the obvious choice would be to have runners the butt up to the sides and tighten it in from each of the four sides. Lets suppose for a second that we want to route the edges whether it be with a bevel or mitre routing bit. The router would hit these runners. Any ideas?!
Stepper motors sound like they could be good enough, as long as they move the router fast enough so as not to burn the wood...Anyone? Assuming an accuracy of +-0.1mm it'd be sensible to have 1 rotation to 0.1mm. I can't imagine this being too difficult (?!)
Thanks,
Gaz
Old 14th May 2003, 03:23 PM   #9
mbroker is offline mbroker  United States
mbroker's Avatar
Send a message via ICQ to mbroker Send a message via AIM to mbroker Send a message via Yahoo to mbroker
Originally posted by Rarkov
[B]Hi,
AutoCAD will export to DXF, which is a plain text, ASCII file. Not sure of the precise contents of a DXF file, but a Google search will turn up something. As I understand it, though, a DXF contains the point data to create lines, curves, and text. You could probably create the NC path in AutoCAD, then export it to DXF. Your custom controller software could read the DXF, and translate it into instructions to send to the controller. Simple in theory, but much harder in execution, especially if you want to optimize the NC path.
Jean-Paul's link shows promise, although I'm not certain if it comes with software. Their english site doesn't appear to say, and the documentation PDF (on the English download page) is in German.
Good luck,
Mark Broker
The Geek Group
http://www.thegeekgroup.org
Old 14th May 2003, 10:40 PM   #10
pinkmouse's Avatar
Your best bet would be a vacuum table. If you build a chamber below the bed and then have a set up program that uses a 1mm drill bit to run holes every 10mm or so, then all you need to do is connect a high power domestic or industrial vacuum to the plenium chamber to suck the air out. This is how some industrial cnc machines work.
If you were machining parts smaller than the bed, you could just use some disposeable bits of thin hardboard, or even a binbag would work, to blank of the unused areas.
As I have more woodworking tools than I can shake a stick at, I don't have any personal need for one of these, (or room!) but if someone could design a PCB milling version that ran on a mac with a USB interface, I would definately be up for one
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Do I need a router? curiousburke Multi-Way 36 9th December 2007 01:18 PM
CNC Router Dryseals Multi-Way 11 7th November 2006 03:01 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 08:19 AM
Copyright ©1999-2013 diyAudio
