Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 14th August 2009, 03:06 PM   #1
ikoflexer's Avatar
Default Scope trace more and more to one side
Got a cheap scope that worked when it arrived, for about a week; it's a Tektronix T922R. All of a sudden, when I turned it on, the trace on both channels showed fine, but half of it outside the screen on the right side. The horizontal position button cannot bring it all the way to the center. As I turned it on and off a few more times, the trace moved more and more to the right, and now it's outside the screen.
Has any of you any ideas what might cause this?
Old 14th August 2009, 04:30 PM   #2
syn08 is offline syn08  Canada
Default Re: Scope trace more and more to one side
http://www.logwell.com/tech/oscillos...921_922_sm.pdf
Ch. 7, "Sweep and Horiz amp"
Old 14th August 2009, 05:27 PM   #3
ikoflexer's Avatar
Thank you, I've been browsing that chapter this morning. I was hoping someone would have had this problem, and have some specific advice, but I guess I'll have to start digging :/
Old 14th August 2009, 06:18 PM   #4
HollowState's Avatar
First, verify that the horizontal mag control is fully counter clockwise in the X1 position. Next, you'll have to open the split case and check the low voltage power supply. This is the small board on the rear bottom side with the transformer. It has four outputs, +100v unregulated, +100v regulated, +8v and -8v. Measure these levels at the pin connector (P7) at the edge of the board. Pin 5 and the metal frame is the common ground.
Pin 1 is +100v reg.
Pin 2 is +100v unreg. (typically +120v)
Pin 3 is +8v
Pin 4 is -8v
While you are there, carefully inspect the solder connections at the P7 connector. Poor solder connections here are a very common problem in these scopes. This also applies to the other pin connectors used elsewhere. Both male and female counterparts.
If the output is low on one or more, you will need to find out why. Keep in mind that these supplies are current limited and will drop when loaded down heavily. So it could be the regulator itself or something downstream in the circuit.
If the supplies are up, you'll have to troubleshoot the horizontal section. (Remember those pin connectors.)
"The human race is just a chemical scum on a moderate-sized planet orbiting round a very average star in the outer suburb of one among a hundred billion galaxies." ~Stephen Hawking
Old 15th August 2009, 04:42 AM   #5
ikoflexer's Avatar
You must know the unit!
Did some poking and pulled the horizontal amp & sweep board out. Powered it with a lab supply, +8V, -8V, +100V. The voltage on the pins P2334 P2344 (sweep to crt) was skewed to positive +90V, and didn't change while turning the horizontal position pot. More poking and the problem ended up being Q2334 and Q2344, both 2N5551. Replaced them with a couple of mpsa42 that I had on hand and now the voltage on those two pins can be nicely balanced to approximately 50V each. Can't test it in the scope because I left it at work but I'm pretty sure it should work.
Thanks again for your pointers guys!
Old 3rd May 2010, 10:12 PM   #6
mjf is offline mjf  Austria
hello.
had the same problem with my leader scope,the horizontal trace moved to the left side and could not be moved to the right...........found out that a transistor (2sa1371) and a res (8,2k blue) in one half of the output stage of the horizontal board were damaged.......
built in new parts and it works again.
greets
Page generated in 0.08677 seconds (75.66% PHP - 24.34% MySQL) with 10 queries
