| Equipment & Tools From test equipment to hand tools |
#161 |
I have plenty of good stuff to give away to some enterprising types. I need space in my storage and its not getting used. You must come to me to get it, however.
Demian Martin Product Design Services |
#162 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#163 | |
no good scope or distortion measuring equipment. I've got the Fluke 87 true RMS Multimeter, a recent find that didn't work when I purchased it (pawn shop). How ever it had been calibrated, dead battery and blown fuse. Had to break the seal to replace the fuse and battery only to find the LCD didn't work. Arrg! I was really surprised that all was needed was a cleaning including the LCD contacts and etc with a little bit of D5 and some pro gold and most of the mater is still working. Next up is trying to fix the speaker/continuity circuit in it. My Fluke 85 Series III is doing just fine. My first meter, My Fluke 21 series II is going south on me with display and other problems. I'll give her a cleaning and see how she does after that. Haven't opened up the B&W scope yet, but thinking maybe a good cleaning is all she needs too. So how high a frequency are we talking about with the Fluke 87? How would that compare to the Fluke 85 III? Thanks, Sync |
#164 | |
It's in the part of the lab in which the critters attain their useful end. |
#165 | |
BSGD -
I seem to recall several "updates" to the HP339A and one I think..... was to make it more stable wrt those "overload" lamps (I don't think they used leds in 1977). There is also a possible factory goof - a missing jumper in some 339A instruments that should be checked for. I'm busy for the next few days, but will try and grab my 339A and duplicate your four simple tests and see what readings I get on one or both of my 339A's. Did you just connect Gen Output to Analyzer Input with no resistors across or what? -Steven Quote:
-- Steven L. Bender, Designer of Vintage Audio Equipment |
#166 | ||
Hi Anatoliy,
They wanted to keep it only because I wanted to take it. I'll bet it's sold or trashed by now. What a waste!There are times when some of that "old gear" is very relevant today. If I see another one, I'll be sure to pick it up. The only ones I have seen were selling for extreme $$ because it said HP on the front panel. Hi bsgd, Quote:
Please, read my suggestions again and retest. Let us know what you get. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#167 |
Fluke Updates:
Fluke 21 Now functioning and operating fine. Fluke 87 True RMS Meter. Had to pull it back apart, re-cleaned everything, and inspected the speaker. When inspecting it I noticed the tiny black rubber standoff on the face of the speaker was damaged. So, it took a bit a patience, of pulling it, turning that standoff around because part of it turned into a point rather then a cylinder. Then I had to superglue it to keep from falling out. I also had to add a few pieces of felt because on leg of the hold down for the plastic back cover was broken and for the speaker to work properly it need full contact with the circuit board. Fluke 85 III The ohm, capacitor, diode meters took a hit. These blink after a brief check, etc. Have to figure that one out. Sync |
#168 |
#169 |
Hi Jack,
That's a really nice, clean job there. I am impressed. -Chris
#170 |
Yet another try to get past the posting woes of the last two weeks...
I have a bunch of dranetz 305C's, great for measuring phase to 700KHz, a 7150, a racal dana 5004, good for low ohms, and some other stuff, 7904, 141T and plugins etc, gets most of what I need. |
| Improving older test equipment-the sequel | Roar Malmin | Solid State | 2 | 2nd August 2009 08:16 PM |
| Page generated in 0.13276 seconds (83.16% PHP - 16.84% MySQL) with 11 queries |
