Go Back   Home > Forums > Design & Build > Equipment & Tools
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Equipment & Tools From test equipment to hand tools
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 29th June 2009, 05:18 PM   #21
figge77 is offline figge77
yes i got the servicemanual, it includes a schematic.
when i was at it i changed the one electrolytic cap, but that didnt do anything any better. tought since its probably 20-25 years old.
Old 8th July 2009, 05:28 AM   #22
I have this problem regularly, and normally I don't need that Meg range. This problem occurs because of the moisture in the pcb due to humid climate. Just heat the pcb under a 40-60watt bulb taking care not to heat the display.
Old 10th July 2009, 08:58 PM   #23
I repair a lot of Fluke meters at work but there have been a few of the old 77's and 23's with this MOhm fault that I just couldnt repair.
I put it down to a fault with the processor but didn't have any replacements to try.
Old 10th July 2009, 10:00 PM   #24
anatech is offline anatech
anatech's Avatar
Hi Flange_UK,
It must be leakage. It could develop in the PCB or divider, or some other component. There may even be moisture under the chip possibly. There is leakage somewhere, and the meter is only indicating what it "sees".
I wonder if sticking the meter in a warm, low humidity environment might work? It might be a week, but that is your best bet right now. If it wasn't such a good meter, you would probably never see this problem as it would be above the range of many others.
Have you cleaned out the function switch? You might want to try carefully removing it and clean it carefully. Hit it with some kind of moisture displacing fluid, then a zero residue cleaner. Lubricate the moving parts and contacts with some "barrier grease" Lithium might work. I've never tried that. Normally, I would have installed a new switch after cleaning the PCB underneath where the switch was.
I have a '77 I still use. It's great as an auxiliary meter on the bench. Heck, it's good enough as a main meter if that's all you've got.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 13th July 2009, 02:03 PM   #25
well thanks for the info.
iŽll take a closer look at the switch.
btw are the 77 and 23 the same?
Old 14th July 2009, 12:14 AM   #26
The 77 and 23 are very similar but the 23 has a slightly better specification.
Thread Tools
Get a Fluke DMM ThSpeakerDude88 Parts 107 21st August 2007 01:40 AM
Fs Fluke 77 Dmm powertriode Swap Meet 2 22nd July 2006 08:52 AM
Fluke 87 repair imix500 Parts 19 9th May 2006 02:52 AM
Page generated in 0.24354506 seconds (56.01% PHP - 43.99% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
