Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 15th June 2009, 04:56 AM   #11
jam is offline jam  United States
jam's Avatar
Hi Chris,
Oddly enough the eraser trick was told to me by a tech at Fluke years ago, it worked on my co-workers Fluke though you had to be very careful and ran the risk of damaging the pads.
I prefer the alcohol method myself and you are right as I should have qualified it by saying Isopropyl alcohol.
Jam
Old 15th June 2009, 07:52 AM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Jam,
I can't fault you for not specifying the type of alcohol used. This is the first time in this thread that I have as well.
The eraser on an elastomer idea makes me grit my teeth just thinking about it! The possibility of damaging the elastomer is very high.
Erasers used on PCB contacts is also a very bad practice. Try that in Agilent's service center and watch what happens! They have proved this technique will probably cause damage as well. You need high magnification to see the damage start, but that fact is undeniable.
Best, Chris
"Just because you can, doesn't mean you should" © my Wife
Old 15th June 2009, 08:20 AM   #13
dangus is offline dangus  Canada
I saved an 87 display by simply flipping the conductive elastomer strip end for end. That put fresh conductive areas in contact with the board and LCD, and all the segments lit up like they should.
Old 15th June 2009, 09:05 AM   #14
figge77 is offline figge77  Sweden
according to the servicemanual:
if ohms reads low or won´t read ol----> shorted Q1 and Q2 or leaky E1 or E2
the E1 and E2 are 1500V surge protectors. can i test them if they are ok somehow? or what can i use as replacement? a wire bridge hehe?
just kidding
will check the transistors aswell but aint gonna be inte workshop in a couple of days.
Old 15th June 2009, 03:29 PM   #15
troystg is offline troystg  United States
troystg's Avatar
Thanks all, I will try it this week.
Again sorry for hi-jacking the thread.
There should be a "sticky" thread in a test instruments group for things like this...
Hmmm, Will have to write the moderators..
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 29th June 2009, 02:37 AM   #16
anatech's Avatar
Hi Troy,
I R 1
Now I feel completely forgotten, ignored. Just another old, forgotten tech from yesteryear.
Hi figge77,
Well yes, check the input circuit. This is the time when a good bench meter comes in handy. You can simply remove them for testing. I have seen a number that were either zapped or had some conductive residue in there.
They should test as an open, however, if you remove them and start getting better readings - guess what?
-Chris
Old 29th June 2009, 03:09 AM   #17
troystg's Avatar
Originally posted by anatech
Hi Troy,
I R 1
-Chris
Oh stop acting like a melodramatic teenager...
I was just thinking out loud when I wrote that.
Troy
Old 29th June 2009, 02:23 PM   #18
i removed the protectors E1 and E2 but to no good. i checked the Q1 and Q2 as mentioned in the sm and they are ok.
well well. life goes on.
Old 29th June 2009, 02:52 PM   #19
jackinnj's Avatar
Uuuuuuuuuuuuuhhhh, did you check the battery first?
Old 29th June 2009, 05:04 PM   #20
anatech's Avatar
Hi Troy,
What can I say?
Hi Jack,
Now, if you just nailed the fault, I'll be laughing pretty hard. Still, there is a "low batt" indicator on the display.
Now that you mention it, I do recall having to replace battery clips often enough on these meters. My memory needed a jog too - thank you!
It's generally the simplest faults that mess us all up.
Hi figge77,
Do you have the manual or schematic for that meter? This fault shouldn't really be a terrible thing to troubleshoot.
-Chris
Get a Fluke DMM ThSpeakerDude88 Parts 107 21st August 2007 01:40 AM
Fs Fluke 77 Dmm powertriode Swap Meet 2 22nd July 2006 08:52 AM
Fluke 87 repair imix500 Parts 19 9th May 2006 02:52 AM
Page generated in 0.10479 seconds (79.06% PHP - 20.94% MySQL) with 10 queries
