| Equipment & Tools From test equipment to hand tools |
Audio Junkie
I am looking for a way to build a device with a know amount of distortion for testing my HP 339A. Something with 1%, 3% 10% doesn't matter as long as it is a known amount.
How would I do that?? |
#2 |
Things like square waves, sawtooth, triangular all have fixed high levels of distortion, the values I do not know offhand. But you could simply mix two known signals together with one representing the distortion could you not ? |
#3 |
I made them in Audition (Cooledit) and burned them onto a CD (not these exactly but other test waveforms).
Pain is never permanent |
#4 |
Audio Junkie
Yeah i have ways to create waveforms including sig gens and soundforge etc, but nothing where i can create a device or a signal with a know about of distortion.
I would like to build a box. some form of op-amp device with a way to create a precise amount of distortion. Zc |
#5 |
Banned
Here is a distortion meter/signal generator. You should be able to create signals with a measured amount of distortion, if only by trial-and-error.
w You can create a signal with arbitrary distortion characteristics by calculation. Values can be created in Excel, for example, for a pure sampled sine wave, which can have a harmonic added at a lower amplitude. Then the values can be turned into a .wav file and played back. Figuring out how to do this is almost as interesting as playing with opamps. |
#6 |
Audio Junkie
Hmmmm, I have a HP 339A distortion analyzer but i need to check how accurate it is.
#7 |
The 339 measures always THD+noise and not THD. You can exclude high and low frequency noise with the build in HP & LP filters, but that will not lead to an exact calibration.
The THD level of a squarewave also depends on its exact 50/50 duty cycle and a very fast rise time. A good & cheap way may be any analyzer-software like Specralab as a reference, but the noise problem is still present. Hardi |
#8 |
http://www.diyaudio.com/forums/showt...21#post1178021
and others in that thread use LtSpice to create .wav files with known components |
#9 |
how about this
#10 |
Banned
Ideal, jacknnj
You can send the fundamental out your L channel and the harmonic out the R channel. However real world distortion is never just in 1 harmonic. But then I guess it's just a ballpark test for a meter. I'd still just combine the signals somehow in the digital domain, and play the result back thru a single channel of a good DAC. Less hardware, less problems. w |
| Where to get Microphone Calibrated | LetGoMyEggo | Everything Else | 3 | 4th March 2009 11:17 PM |
| source of distortion??? | Dan2 | Car Audio | 6 | 11th February 2009 11:09 AM |
| Calibrated DAC with one chip per bit ? | Bernhard | Digital Source | 8 | 17th May 2005 12:27 AM |
| Microprocessor Calibrated Amp. | Brian Guralnick | Solid State | 11 | 29th October 2002 07:29 AM |
| Page generated in 0.11506 seconds (77.10% PHP - 22.90% MySQL) with 11 queries |
