| Equipment & Tools From test equipment to hand tools |
#41 | |
And in order to get less than 1% relative error on the distortion, you only need up to the 25th harmonic. I didn't make the calculations for 0.1%, because as has been pointed out, such an accuracy is totally ludicrous for distortion measurements. 1% is already extremely ample. |
#42 | |
http://www.vk1od.net/SquareWave/THD.htm If that's where you got the number, you should be aware that the calculation on that page is in error. In Figure 2, he has the function f(x) = (1 - 4/pi*sin(x))^2, which is the correct function up to that point. But in Table 1, he left out the 4/pi factor in the calculation for the RMS responding meter (and the average responding one, too). If you put back this factor and do the calculation, you will get 43.5% distortion for a square wave. Or, work it out from the definition of THD: Total power of harmonics ---------------------------------------------------- Total power of (fundamental+harmonics) like this: SQRT(1/9 + 1/25 + 1/49 +...+ 1/(2n-1)^2) --------------------------------------------------- SQRT(1/1 + 1/9 + 1/25 + 1/49 +...+ 1/(2n-1)^2) Let n be 1000 or so, and use Matlab or something to add them all up and you will get something around .435 The theoretical value for n -> infinity is 100*SQRT((pi^2-8)/(pi^2)) = 43.52362% You can also use the quotient of series to find that including up to the 87th harmonic (n=44) will give a value of 43.0906%, just a tiny bit less than 1% smaller than the exact theoretical value. |
#43 | |
#44 | |
http://zone.ni.com/devzone/cda/tut/p/id/3401 It is the definition generally used in Europe for audio purposes. I'm aware other definitions exist, including yours. I will certainly not take sides in this matter and say that my definition is better than yours; the important thing is to know exactly what we're talking about. Anyway, when distortion figures are small, the two methods give very close results; in the case of a square wave, there are significant differences, and in particular, the much slower convergence with your method, due to the presence of the harmonics in the denominator of the expression. Also note that in the case the square wave is "diluted" in a large amount of fundamental, both methods will yield similar results and will converge at speed of "my" method: i.e. 1% relative accuracy obtained at 25th harmonic. |
#45 | |
RMS value of harmonics --------------------------------------- RMS value of (fundamental+harmonics) The definition you are using is used by the power industry in the U.S. See: http://en.wikipedia.org/wiki/Total_harmonic_distortion They say: "...for audio measurements 100% is preferred as maximum, thus the IEC version is used (Rohde & Schwartz, Bruel and Kjær use it).", and then they show a definition which is the same as that used by the 339A, squared. This definition has the power of (fundamental+harmonics) in the denominator instead of just the power of the fundamental. I would have thought that Rohde & Schwarz or Bruel and Kjaer would be common instruments in Europe, and that the IEC method would be the one commonly used in Europe for audio measurements. Can any Europeans verify the method used by the aforementioned European instruments? But regardless of which method is common in Europe, the theoretical distortion for an ideal square wave, including all the harmonics, using the method you're using (the IEEE method referred to in the Wikipedia article, and also on the web page you referenced: http://zone.ni.com/devzone/cda/tut/p/id/3401) is not 46.7%, but rather 48.34%. The exact value is 100*SQRT((pi^2-8)/8) = 48.34258...% The distortion of a square wave up to the nth harmonic can be calculated for the definition you used (the IEEE definition) like this: RMS value of harmonics ------------------------------ RMS value of fundamental or: SQRT(1/9 + 1/25 + 1/49 +...+ 1/(2n-1)^2) ---------------------------------------------- 1 If I use the figure you have given for the distortion of a square wave, namely 46.7%, then the expression just above is indeed within 1% of 46.7% when harmonics up to the 25th are included, but as I said the 46.7% number when using your definition of THD is incorrect. If you use as a reference the correct figure of 48.34258%, harmonics up to the 107th must be included to get 1% relative accuracy. |
| Where to get Microphone Calibrated | LetGoMyEggo | Everything Else | 3 | 4th March 2009 10:17 PM |
| source of distortion??? | Dan2 | Car Audio | 6 | 11th February 2009 10:09 AM |
| Calibrated DAC with one chip per bit ? | Bernhard | Digital Source | 8 | 16th May 2005 11:27 PM |
| Microprocessor Calibrated Amp. | Brian Guralnick | Solid State | 11 | 29th October 2002 06:29 AM |
| Page generated in 0.11819 seconds (82.37% PHP - 17.63% MySQL) with 11 queries |
