| Equipment & Tools From test equipment to hand tools |
I built up a MAX038. I get a sine wave with the peaks slightly skewed. Does not matter what frequency it is set to. The supply voltages are +/- 4.92V. What causes this slight shift? Any ideas what to look for? I used this circuit: www.kitsrus.com/pdf/k101.pdf Thanks. |
#2 |
You need to lift pin 7 (DADJ) from GND and make it adjustable between a volt or so pos and neg - something like the FINE adjust but then between + and -. That will let you adjust the symmetry of the waveform.
One way to test it is to look at the square wave output (NOT the sync output - that is always 50%) and adjust as best as possible for 50% duty cycle. It's all in the data sheet, by the way... Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
thanks. I will give that a try. I wonder how the kits they sell get away without having to make that adjustment. I'm using all the same values and parts.
#4 |
Doesn't look like a symmetry problem. I'd rather say there is some leak from the square wave to the sinewave, perhaps caused by charge injection or something similar.
Might be caused by a poor layout, or it could happen internally in the MAX038. Even if this is the case you could correct it by injecting a square of opposite phase into the sine output, through a high value resistor f.e. |
#5 |
it could very likely be my layout. I'll look into it further when time permits. thanks.
#6 |
Looking at it again, it may well be the graph itself. The line is quite thick and jumps one or two pixels at the time.
What equipment/program did you use to make it? If you look on the scope, do you still see those jumps? Probably not! Jan Didden
#7 |
actually, I just cut and pasted a sine wave from the wave
to show as an example of what I see on the oscilloscope :-) my respects to your great attention to detail. I had the max 038 part so I wanted to give it a try. it's working but not great so I need to spend some more time on it. |
#8 | |
So maybe there isn't a problem at all. Maybe a pic of the scope screen would be more clear. Jan Didden
| Sine Wave Generator with bulbs (Sine-lightenment) | Rodeodave | Everything Else | 6 | 21st July 2008 12:19 PM |
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 12:15 AM |
| Pure sine wave? | PeteMcK | Multi-Way | 12 | 4th July 2004 06:31 AM |
| Page generated in 0.08393 seconds (80.42% PHP - 19.58% MySQL) with 11 queries |
