Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 22nd November 2007, 05:44 PM   #11
percy is offline percy  United States
still haven't tried LTspice or Scilab but ended up writing a script to generate my own sine wave! I even wrote my own function to calculate sine based on taylor series. Its interesting how much precision (atleast 7 digits after the decimal point for 16 bit depth) is required to avoid rounding errors and take the precision upto or less than 1LSB.
I have yet to add the file creation part to write to a pcm wav file. Once that is done I will know how much distortion there is in the produced wave, or lack thereoff.
In v2.0, complex waves - ability to add harmonics with variable amplitude!
I wonder if these packages, or the languages they are written in, have the kind of precision for these type of operations.
Old 23rd November 2007, 08:02 AM   #12
Originally posted by Pan
it's the other way around. A square wave is made up of lots of sinewaves.
not when the system (DAC) is trying to reconstruct an analogue signal (sinewave) from a digital datastream.
If you do breakdown a squarewave into it's components one finds that the harmonics go out to infinity. That is the problem. The digital datastream runs out of bits in the range of 44Ks/S to 192ks/S. I have seen it estimated that a good approximation to a squarewave can be reconstructed if all the harmonics up to the tenth are included in the signal. To reconstruct a reasonable 96kHz squarewave would require a bit rate of 1Ms/S or looked at from CD datarates it should be possible to get a 4kHz squarewave from the DAC. I suspect that even a 4kHz sinewave coming out of a CD DAC will show significant distortion.
Does anyone have any figures?
regards Andrew T.
Old 17th December 2007, 09:05 PM   #13
6 digits of precision(i.e. after the decimal point) and processing the sine series(taylor polynomial) up to the 9th degree is what you need in the least to create a sine wave with distortion buried in the noise floor.
Note that I did not say "without distortion". It is there, just not discernable.
I had been fooling around with creating a wav file of a pure tone and observing what kind of loss of precision generates what kind of distortion and thought I'd share some results with you.
It is a common belief that computing upto the 7th degree of the Taylor series for a sine function is a good enough approximation for a sine function.
Wrong. You need alteast one more degree i.e. upto 9th degree to achieve a sine wave which has very little distortion.
Here's a screen shot of the FFT of a 500hz sine wave produced with the sine function computing only upto the 7th degree -
Old 17th December 2007, 09:06 PM   #14
and here's a screen shot of the FFT of a 500hz sine wave produced with the same sine function, but computing upto the 9th degree -
FFTs were done with the spectrum analyzer provided in RMAA 6 with a Kaiser window of atleast 15.
Old 19th December 2007, 06:25 PM   #15
Pjotr's Avatar
Default Re: Tone Generator - Multiple Tones and Variable Amplitude
Originally posted by percy
I am searching for PC based tone generator that will allow adding multiple tones with variable amplitude. For example, 1Khz at -3db, 2Khz at -40db, etc...
Also it has to be capable of creating tones at 92Khz or higher also.
Right now I have the NCH Tone Generator that has multiple tones and variable amplitude but unfortunately its fixed at 44.1Khz so can't add any frequency above Fs/2.
Any help greatly appreciated!
TiA!
FYI, have also a look here: http://www.fesb.hr/~mateljan/arta/
It works with 192 kHz soundcards as well. The build-in sine generator can do dual tones with adjustable ratio quite accurate. Attached a picture of a loop through measurement of my USB soundcard at 44.1 kHz.
Old 20th December 2007, 02:17 PM   #16
I don't think it can save it to a wav file, does it ?
I want a "generated" wav file, not a "recorded" wav file (to avoid introducing deficiences of the playback + recording chain).
Amplitude and frequency distributions wanted DouglasSelf Solid State 12 20th January 2012 10:18 PM
Pressure sensor to control amplitude Dogue Instruments and Amps 7 15th October 2008 11:22 PM
Why do sweep signals have progressively decreasing amplitude ? percy Equipment & Tools 6 13th February 2008 12:08 AM
Audio Signal Amplitude Levels..? xitronics Analog Line Level 0 16th October 2006 04:19 PM
Page generated in 0.09322 seconds (82.77% PHP - 17.23% MySQL) with 11 queries
