| Equipment & Tools From test equipment to hand tools |
I built the P86 circuit: http://sound.westhost.com/project86.htm I would like to extend the range from 20hz to 20KHz. with the suggested values changes for C8 and C9 to 0.15uF and R8,R9 to 2K, I get the following: Low Range 20Hz - 531Hz Hi Range 785- 20415Hz I need help on how to get the low frequencies to overlap. Since I'm missing frequencies between 513Hz and 785Hz. Thanks. |
#2 |
You may have to alter the 2.2k resistors going to the dual 50k pot.
I left the caps as in the schematic, but put 2k trim pots in place of the 2.2k resistors. See my post... http://sound.westhost.com/phpBB2/viewtopic.php?t=1801 =RR= |
#3 |
thanks RR,
I got it working and testing with a small amp and speaker. I don't have a scope yet to see how it looks. neat little circuit. Thanks to Rod! |
| ultra-low distortion audio oscillator | geekysuavo | Analog Line Level | 14 | 8th September 2011 10:51 AM |
| Use of a Ribidum Oscillator as refrence oscillator in a DAC | Mark A. Gulbrandsen | Digital Line Level | 18 | 2nd January 2009 09:57 PM |
| 10 MHz oscillator possible to use ? | Bernhard | Digital Source | 7 | 28th August 2007 09:07 PM |
| oscillator | dsavitsk | Tubes / Valves | 9 | 15th November 2005 06:07 PM |
| Page generated in 0.05908 seconds (73.26% PHP - 26.74% MySQL) with 10 queries |
