Solder vs crimp? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 17th June 2007, 07:40 AM   #1
Default Solder vs crimp?
I've always been a "solder" person for connecting cables to connectors, but I'm just in the process of putting some ring terminals on 4AG cable for the p/s caps. Soldering this size doesn't seem to really be an option. So will probably crimp, but I wanted to hear other views on pros/cons of crimping.
Old 17th June 2007, 07:46 AM   #2
Hartono is offline Hartono  Indonesia
the biggest (hugest ?? ) solder on spade that I ever saw is in Wilson Watt-Puppy bass cable, it's HUGE , so soldering is still possible.
Hartono
Old 17th June 2007, 07:57 AM   #3
The biggest (hugest!) problem is getting enough heat in to get a good solder joint without melting the insulation (which isn't teflon unfortunately). I've tried a blowtorch but still didn't give good results - maybe I need to get a 200W iron....
Old 17th June 2007, 08:06 AM   #4
yes I know, blowtorch doesn't seem to do very well (because the air is not a good conductor of heat ?). I should've checked what insulation they use.
the bad thing about crimping is when the crimping connection is not perfect and develop oxidation at the contact point. so dissimilar metal could be troublesome on the long term.
another way is solder multiple smaller cable on separate ring and connect them together using copper bus bar.
Old 17th June 2007, 09:11 AM   #5
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I don't have a big enough crimping tool to do something like that and don't have a blowtorch either.
what I do is lay the connector on an anvil of some sort and bash it flat with a hammer.
haven't had problems with it.
Old 17th June 2007, 09:17 AM   #6
Hi djQUAN,
you're the man , It might not look like it but I laughed so bad ( I found it very practical, and very funny at the same time)
well, it works !!!
Hartono
Old 17th June 2007, 10:19 AM   #7
You should read .........thread below
http://www.meadowlander.com/splice/splicingpart3.html
Old 17th June 2007, 10:22 AM   #8
ooops dont forget to look at part 1 & 2.....
Old 17th June 2007, 01:34 PM   #9
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
I donīt have crimping pliers, so when I want to use fastons, I first crimp them a little with normal thin pliers (or a srewdriver and hammer or anything else), and then when it holds together I solder it.
Old 20th June 2007, 12:02 PM   #10
OK, I picked up a 175W soldering iron today and the results are good. I can get a good connection with minimal damage to the insulation, so I think I'll go this way. Tries a few of the crimping options suggested and results are ok, but I'm still not convinced the connection is as good as solder...
Thanks for your comments
Fry Solder? jol50 Parts 0 25th November 2007 10:44 PM
Best solder to use rtarbell Parts 4 20th November 2005 01:05 AM
what solder should be used ?? kambule Parts 27 8th August 2005 01:16 PM
Which Paladin die to crimp these ring terminals? andy_c Parts 3 27th August 2004 02:14 PM
how do you solder? theChris Equipment & Tools 15 2nd January 2003 10:55 AM
Copyright Đ1999-2017 diyAudio
