Equipment & Tools From test equipment to hand tools
RADFORD - Low Distortion Measuring Set
Old 15th January 2007, 11:20 AM   #11
TomWaits is offline TomWaits  Canada
TomWaits's Avatar
Default Re: Radford Batteries ...
Originally posted by torroid88
Good enough for a "dead or alive" test though !
Good Luck !!!
Interesting link as I did not think such a cell was available anymore. If it works well, I'll build a power supply for certain.
Thanks,
Shawn.
Old 15th January 2007, 09:02 PM   #12
latala is offline latala  United Kingdom
Those cells are PP9 over here(uk) and are still available !
Nice to look inside the radford typical build quality for them !
I have a zd22 preamp and a large [power amp of theirs and the build style is very similar.
regards Trev
Old 22nd November 2007, 08:59 AM   #13
big jim is offline big jim  England
hi tom i have the manual if you still need it.
all the best jim
Old 22nd November 2007, 11:42 AM   #14
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
If that manual also contains the schematics, I would be very interested in seeing a pdf of that manual, as the oscillator appears to be among the very best..........
and Tom - I think you should seriously concider getting those batteries, as they probably plays a rather important role in keeping the noise floor all that way down. ( Rechargeable 9Vs could be another way...)
Old 22nd November 2007, 04:01 PM   #15
Originally posted by AuroraB
I think you should seriously consider getting those batteries, as they probably plays a rather important role in keeping the noise floor all that way down. ( Rechargeable 9Vs could be another way...)
and completely isolate the charging system, including ground, before connecting the analyser to the circuit under test.
Maybe a TRS jack plug & socket that prevents insertion of input/output plugs until you've disconnected the charger.
Even the face plate looks worth $50.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd November 2007, 04:17 PM   #16
Conrad Hoffman is offline Conrad Hoffman  United States
I have some equipment that uses a bunch of #246 9V batteries, a bit smaller than your behemoths. Curious, I carefully opened the bottom of the box to see what was inside. Amazingly, there was a little circuit board with the exposed terminals on top, a couple perfectly standard 9V batteries plugged into terminals on the bottom, and a wood spacer to take up the rest of the space! You probably won't be as lucky, but I can now just plug new 9V batteries into mine, which is about 10X cheaper than buying new #246 batteries. I didn't know one could parallel batteries, but if the voltages are matched, it obviously works. Might be a way to run your unit, as it would probably exhaust the normal size batteries very quickly.
RADFORD - Low Distortion Measuring SetHide this!Advertise here!
Radford distortion meter D.M.S. SERIES 2 big jim Parts 1 18th July 2016 05:47 PM
Measuring distortion Buzzy Multi-Way 5 5th November 2008 05:44 PM
Measuring current distortion mashaffer Tubes / Valves 0 25th September 2008 10:37 AM
Measuring driver distortion otto88 Multi-Way 9 18th June 2008 01:59 PM
measuring distortion/ZenV7 PassFan Pass Labs 2 18th August 2004 12:51 AM
Copyright ©1999-2017 diyAudio
