Equipment & Tools From test equipment to hand tools
can your 'scope do this?
Old 30th June 2006, 01:06 AM   #1
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default can your 'scope do this?
some microvolts into a Tektronix 5223 digitizer with 5a22n differential amplifier:
Old 30th June 2006, 02:46 AM   #2
Christer is offline Christer  Sweden
No
Old 30th June 2006, 04:00 AM   #3
Stocker is offline Stocker  United States
Thumbs up say, that's pretty neat...
Yeah, well, well,
my scope has more buttons than your scope!
Jesus loves you.
Old 30th June 2006, 05:07 AM   #4
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Jackinnj,
How can I get this picture on the scope? The upper is the basic sinewave, the lower is the distortion component, but they both appear at the same time at the same scope?
Old 30th June 2006, 09:29 AM   #5
jahonen is offline jahonen  Finland
jahonen's Avatar
I guess not directly.
But how about this: Measuring three channel single sweep at 50 ms/div, and then zooming at the details without recapturing the signals to 200 µs/div
lumanauw, I believe you'll need some kind of filter to pick up the desired distortion component(s) and eliminate the fundamental.
Janne
Old 30th June 2006, 03:15 PM   #6
lumanauw's Avatar
How to do it? First I tought it is done by somekind of scaled X - Y
Old 30th June 2006, 03:21 PM   #7
jackinnj's Avatar
use an active T-notch filter -- this will give you THD+N -- to just get THD you need to count the magnitude of each harmonic -- which you can do in DSP -- design of such a filter can be found on Texas Instruments and Analog Devices websites.
fwiw -- the USB1208FS and Softwire (or other software packages) can do this pretty easily.
the 5223 example shown at the start of this thread is a scope used for low noise applications -- while technically part of the 5xxx series of boatanchors it has many of the features of the 7xxx devices but the bandwidth is quite limited.
can your 'scope do this?Hide this!Advertise here!
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 10:59 PM
My first scope! bigwill Equipment & Tools 3 7th July 2006 06:10 AM
10 Mhz Scope enough ?? Henrik Juhl Equipment & Tools 24 20th October 2004 07:05 AM
PC as a scope Ryssen Equipment & Tools 3 2nd January 2004 10:50 AM
Copyright ©1999-2017 diyAudio
