Equipment & Tools From test equipment to hand tools
Used scopes...
Used scopes...
Old 9th June 2006, 04:16 AM   #21
john curl is offline john curl  United States
john curl's Avatar
I have used 3 TEK 485 scopes over the last 32 years. I love my 485, it is one of the best scopes ever made. I also have a TEK 7633 analog storage scope. I have used one of these, off and on, for 29 years. It is pretty good, but I don't use it much. I have big Hickock military scope, originally with Vietnam dirt inside it. It takes 2 men to move it, and finally I have a TEK 585 scope with 'traveling wave' drive, and it gives the best spot of all.
Old 9th June 2006, 05:38 AM   #22
jh6you is offline jh6you
Account Disabled
TEK422 (15MHz) also recommended?
Old 9th June 2006, 05:56 AM   #23
john curl's Avatar
Kind of slow. Had a 3'' scope that slow once, but I gave it away, when I got something faster. Not a good first choice.
Old 9th June 2006, 06:18 AM   #24
PMA is offline PMA  Europe
PMA's Avatar
I loved Tek 556. True double beam, with trans. and valves. IMHO the best analog scope. Worked with 7844 then, and it was not that good. I needed fast recovery after heavily overloaded, operating in high EMI environment.
Old 9th June 2006, 10:53 AM   #25
Account Disabled
Thanks, John Curl. I will consider 485.
Old 9th June 2006, 12:14 PM   #26
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Used scopes...
high EMI environment -- did you have one of these on the 7844?
Old 9th June 2006, 12:29 PM   #27
PMA's Avatar
Not exactly, we had a custom made case.
Old 9th June 2006, 12:44 PM   #28
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
A cat flap?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th June 2006, 01:01 PM   #29
jackinnj's Avatar
Used scopes...
it's an EMI screen from a R7704 which I parted out --
Used scopes...Hide this!Advertise here!
New scopes apassgear Parts 0 26th November 2008 10:20 PM
Scopes Onvinyl Equipment & Tools 0 28th September 2006 05:41 PM
Scopesī TroelsM Parts 0 16th June 2006 06:50 AM
New TEK Scopes Bryan Tubes / Valves 22 25th November 2005 12:56 PM
