Equipment & Tools From test equipment to hand tools
What's a good beginners Oscilloscope?
Old 22nd July 2003, 12:47 AM   #31
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Oh no! For $500 you can do much better than that! A used Tek or HP will be far better. FFT is nice, but oscilloscopes don't have much bit depth, so don't expect to be able to use it as a distortion analyser.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 22nd July 2003, 01:19 AM   #32
sam9 is offline sam9  United States
sam9's Avatar
For my own edification, what would be considered adequate bit depth. The newest Pico-Tech units claims 16.
Old 22nd July 2003, 01:22 AM   #33
sam9's Avatar
Meant to add, that's with a 333kS/s sample rate. I'm not that familiar witnh what that implies for scopes used for audio.
Old 22nd July 2003, 01:24 AM   #34
EC8010's Avatar
16 bits is great. Trouble is, you also need a good sample rate for an oscilloscope. 20MS/s is adequate, but more is better. Digital only approaches analogue when the sample rate is really high. A 5GS/s oscilloscope makes a pretty good stab at looking like analogue.
Old 22nd July 2003, 01:29 AM   #35
EC8010's Avatar
Originally posted by sam9
Meant to add, that's with a 333kS/s sample rate. I'm not that familiar with what that implies for scopes used for audio.
It means that if your input signal has anything above half that rate, it will be completely distorted. You now have a bandwidth of 167kHz. You might think that's enough, but it's not nearly enough. You need at least 20MHz.
Old 22nd July 2003, 03:08 AM   #36
sam9's Avatar
Point taken. Same principle as bit rate in audio recoding - 2x the highest frequency. That definiately would not have identified some osciliation problems I've had.
Old 22nd July 2003, 04:36 AM   #37
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Don't waist you time with pc scope. you loose all of the portabillity and won't have the resolution. A nice Tec 465 can be had on Ebay for $300. I went a little cheaper and got a B&K for $60 (only 20mhz) Works great and came with owner and service manual.
Lots of people talk about 7XXX tecs, but I would thing about size and weight if you don't have a permanent audio workbench like me.
Old 22nd July 2003, 05:56 AM   #38
sam9's Avatar
A B&K for about $60-70 is what I've actually got. In terms of benefit/$ it's about the best piece of gear I've got. I had an "oscillation situation"ot long ago that I would not have been aware of (until smoke appeared!) with the limited bandwidth of a PC scope. I was thinking more of augumenting it with affordable FFT capability even of limited to the audio band plus a little more.
Old 22nd July 2003, 08:13 PM   #39
For that use, one might be nice to have. Expecially if you also have some toher real time soundcard based speaker testing software on a machine dedicated to stereo stuff. If your talking about miked speaker test (or whole system test) a full duplex sound card can test speakers while ignoring room interaction. And it makes a decent function generator too.
Old 22nd July 2003, 08:22 PM   #40
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
here is a pc based scope to play with
I would still buy a real one....the tek 465b is not a bad scope and can be expanded.
DIRTŪ
What's a good beginners Oscilloscope?Hide this!Advertise here!
Good Oscilloscope? spooney Car Audio 10 15th March 2008 06:33 PM
F2 for beginners vitalstates Pass Labs 6 24th January 2007 01:02 AM
A good book for beginners!? Stefanoo Pass Labs 23 19th October 2006 02:32 PM
beginners q's lt cdr data Solid State 3 23rd May 2005 10:59 PM
Good books for beginners Yesfan70 Everything Else 7 24th April 2005 02:54 PM
