Equipment & Tools From test equipment to hand tools
Useful tools and techniques
Old 14th July 2002, 08:10 AM   #51
cjunk is offline cjunk  Italy
Default Aluminium panel finishing
How do you finish your aluminium panels?
Are there easy and feasible ways to remove the scratches of the drilling and assembly process?
I would like to preserve the natural color of the aluminium without anodizing it.
Carlo
Old 14th July 2002, 03:06 PM   #52
Coulomb is offline Coulomb  England
Coulomb's Avatar
Default Finishing Aluminum
There are several methods you can use, I like to lightly sand blast my heasinks after machining. For flat panels the best method is soap, water and a brillo pad, always push in striaght lines and in one direction only. I have attached a photo showing a project where I used both methods of finishing.
Anthony
Old 14th July 2002, 03:06 PM   #53
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Useful tools and techniques Send a message via AIM to Peter Daniel
This is a closeup of a preamp panel I made in early '80s. There was no protection done to aluminum surface of any kind and after extensive use you don't see any wear after all those years. I finished it simply by using fine grade waterproof sandpaper (between 200 to 400, depending on your likening). If you do it wet the surface will become matte, when do it dry it will have a shine. Just use a piece of wood to move your panel along it's edge, so the brushed lines are perfectly straight. After that clean it with hot water. Dry immediately because water might leave spots. That's my memries of making the panel then.
Today I'm using 6" belt sander. I simply sand the panels on it, using WD40 as a lubricant and 150 grid paper. One might use different lubricant but since it's working for me I didn't bother to look for anything else. After that I clean the panel with Varsol and give it a final look with Scotch Brite.
To see more pics of the preamp see: http://www.diyaudio.com/forums/showt...3046#post43046
Old 14th July 2002, 04:08 PM   #54
It's pretty hard to capture fine texture of aluminum in difficult light but maybe that picture shows it better.
Old 14th July 2002, 04:33 PM   #55
Anthony,
Using soap sounds interesting, I never tried it before. What's brillo pad?
Old 14th July 2002, 05:27 PM   #56
cp642 is offline cp642
Brillo pads are scouring pads, something that resembles Scotch-Brite.
Old 14th July 2002, 05:42 PM   #57
Coulomb's Avatar
Default Re: Brillo
Hello HPotter, cp642 is correct.. though I tend to keep a few different types at my disposal to work with. First the Soap acts as a lubricant to control the abrasive action and smooth the stroking process. I use a copper pot scrubber for rough finish then follow up with the presoaped little steel wool pads for polishing. The plastic types are useless of course. I tried sand paper but never got the sheen I wanted and it seemed messier. I do all the polishing under luke warm running water and have not had the experience of a dull finish from wet working.
Anthony
Old 14th July 2002, 06:30 PM   #58
You get matte finish when using high grid sand paper (300 and more) and water (no soap, because you want to find the most abrassive stroke).
Old 14th July 2002, 06:37 PM   #59
Coulomb's Avatar
Default Re: Matte Finish
Humm.. Sounds cool, maybe I will give it another try.
Old 14th July 2002, 09:39 PM   #60
PedroPO is offline PedroPO  Portugal
PedroPO's Avatar
Send a message via ICQ to PedroPO
In my panel I used 320 sandpaper without water or soap.
I didn't use a ruller so the lines were a bit on the curve side, but I think is ok for the first job.
after I lackered it with semi gloss and finished with car polish
here is a pic
Pedro Oliveira
Useful tools and techniquesHide this!Advertise here!
Crossover construction techniques wiredmonkey Multi-Way 13 25th April 2009 03:27 AM
Woodworking techniques johngalt47 Multi-Way 33 11th March 2009 07:07 AM
Transistor biasing techniques keantoken Solid State 22 21st September 2006 05:13 PM
Techniques SL-230 rewire justn Analogue Source 5 1st October 2005 06:36 AM
Copyright ©1999-2017 diyAudio
