Equipment & Tools From test equipment to hand tools
Useful tools and techniques
Old 15th January 2006, 03:13 PM   #321
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally posted by fcel
what is that?
It's a pizza oven used in bars -- particularly good for pizza bagels, box pizza, texas toast, mini-quiches, samosas -- all those stinky high fat foods which go great with a beer.
Old 15th January 2006, 04:20 PM   #322
poobah is offline poobah  United States
poobah's Avatar
Stabist,
You must apply clear paint to your copper after brushing it... clear polyurethane will do a good job.
Old 2nd July 2006, 06:15 PM   #323
BluP is offline BluP  Croatia
Default esp project 97
does enybody have how the PCB from esp project 97 looklike???
i'm planing to do it but i don't want to project everithing myself so if enybody have it please paste an image!
Old 27th September 2008, 11:18 PM   #324
sianturi is offline sianturi  Indonesia
sianturi's Avatar
Now how do you make a BIG recessed hole like this with aluminium?
The Great Saiyaman
Siapa bertelinga hendaklah ia mendengar... (Mat 13:9)
Old 28th June 2009, 12:23 AM   #325
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Forstner bit:
Cutting oil or alcohol and a drill press. Drill a pilot hole for the Forstner bits tip first.
Old 2nd July 2009, 04:49 AM   #326
Bonsai is offline Bonsai  Europe
Default Soldering Iron
Heres a quick tip.
My Weller soldering iron station burnt out about 4 years ago.
I simply replaced it with a Dell Laptop charger.
Works like a charm. As an added bonus, I can use it anywhere in the world now - 240VAC in Euroland, 100VAC here in Japan and wherever else they send me next.
Old 31st August 2009, 07:52 PM   #327
TerribleT is offline TerribleT  United States
Default Circular saw table attachment
Useful tools and techniques-saw1-jpg
Originally Posted by Peter Daniel View Post
For anything that doesn't fit my mitre saw I'm using that setup. I bought that table long time ago at Canadian Tire and although desined for wood cutting it works great with metals. I'm using 7.5" circular saw which can slide above the table. I clamp aluminum pieces to the table. I was cutting 1" thick aluminum pieces as well as 2" thick heat sinks without a problem. When a piece is thicker I do two or three runs to complete the cut. Don't forget about the safety glasses.
Can ytou tell me the make and model of the saw table and where I can get one? It looks like something I can use with my wormdrive saw.
Thanks,
David
Old 31st August 2009, 08:49 PM   #328
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Useful tools and techniques Send a message via AIM to Peter Daniel
It's Triton: http://www.triton.com.au/product.php?id=13
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Useful tools and techniquesHide this!Advertise here!
Crossover construction techniques wiredmonkey Multi-Way 13 25th April 2009 04:27 AM
Woodworking techniques johngalt47 Multi-Way 33 11th March 2009 08:07 AM
Transistor biasing techniques keantoken Solid State 22 21st September 2006 06:13 PM
Techniques SL-230 rewire justn Analogue Source 5 1st October 2005 07:36 AM
Copyright ©1999-2017 diyAudio
