Equipment & Tools From test equipment to hand tools
Multimeter recommendations?
Old 9th June 2002, 10:39 AM   #11
walker is offline walker  Australia
Send a message via ICQ to walker
I've always stuck to Flukes, I once had a cheap digital but in those days they often gave weird readings on anything other than power frequencies and sine waves. I suspect that things have got better in the cheap end of the market over the last 20 years.
I spent 5 years teaching, late 80s early 90s, the training department had Beckmans. The Beckmans seemed to give good and accurate results but would die if abused. I replaced the Beckmans with Flukes and never had an ounce of trouble.
I currently use Fluke 97Scopemeter, 2x87, 6080A, 23, 12. The 6080A is over 20 years old and was recently sent in for calibration, come back with a clean bill of health, it passed without adjustment!
I would not be without an analogue meter, I use them for measuring audio signals other than stable sine waves. I use AVO model 8 and Philips PM2504, damn fine machinery.
An analogue CRO, (oscilloscope) is also invaluable at times but its rarely needed.
Regards WALKER
AudioFreak, don't be suduced by high count displays, they're rarely stable or accurate unless you pay the big bucks.
Old 9th June 2002, 12:48 PM   #12
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Walker,
That was the point of my post... quality is the 1st objective cost comes somewhat later.... any good meters you know of that meet or better those specs regardless of price??
Old 9th June 2002, 01:40 PM   #13
The problem with buying a multimeter on specs is that you cant tell how long they will stay in calibration and more importantly how good the ADC and input filer is. Cheaper meters often run out of accuracy at a couple of hundred hertz and perform abysmally on waveforms other than sine waves.
Sorry but I can't recommend a cheap brand of meter, I stopped using cheap meters years ago.
Regards WALKER
Old 9th June 2002, 02:15 PM   #14
Warp Engineer
On Holiday
AudioFreak's Avatar
Let me rephrase that, I am not looking for a cheap meter... I dont care about the price ... whatever i have to pay, if it is reliable accurate and does what I want of it, I am willing to pay it ... I'll worry about how I am going to pay for it at a later date.
Old 9th June 2002, 02:45 PM   #15
AudioFreak, sorry I think I finally got the message. I don't know of a one meter that does everything you wan't well.
I have a digital LRC bridge for reactive components but often measure the reactive voltage or current values in situ and calculate the capacitance or inductance.
Apart from that you probably noticed my Fluke bias, having said that any well knlow quality brand gear should do fine.
Make sure you check the frequency limits of the equipment both high and low and remember that the limit is usually the -3dB point so it should be well above or below the frequences needed.
Regards WALKER
Old 9th June 2002, 04:05 PM   #16
Warp Engineer
On Holiday
AudioFreak's Avatar
Thanks,
Freaky.
Old 9th June 2002, 05:10 PM   #17
phishead8 is offline phishead8  United States
phishead8's Avatar
At the research laboratory that I work in we have several types of multimeters. But, there is no question about it, the couple of Flukes that we have are relied upon when undisputed accuracy is required. The other types of multimeters are resting on our shelf, while the Flukes are practically being fought over.
I recently pulled some old meters out of the salvage pile. They are the duarable little boxes that are from the pre-war science era. Manufactured by Weston Electrical Instrument Corp. back before plastic was invented. I've given them different amounts of voltages and currents, and they work perfectly. They are quite accurate and have a fast response. Boy, do they look good sitting on the workbench.
But, when I need to measure mundane things such as resistance and such I rely on my own Fluke 77.
-Dan
Old 9th June 2002, 08:25 PM   #18
cocolino is offline cocolino  Germany
cocolino's Avatar
Any suggestions on a really good 10,000+ count digital multimeter for lab work??? Benchtop or portable, Voltage, Current, Resistance, Capacitance, Inductance. PC uplink preferable.
The only high quality DVM I know that does everything You`ve asked for (and more) unless the inductance, is a Philips (Fluke) PM2525.
special features (besides the usual auto-ranging Volt, current): TRMS up to 100kHz; AC+DC volts; V peak either positive, negative or peak-to-peak; 4-wire resistance measurement; 20nF to 2000 uF full-scale; wide-range dB function + zero set function + db-reference set function; frequency to 20 Mhz; time 1 to 10^5 seconds full scale; temperature (with optional probe); diode check function; continuity with beep function; analog bargraph display; selectable high/low resolution modes; IEEE 488 - RS232 - IEC-625 interface options.
I doubt that there is a high quality meter that has a similar amount of features (or includes the inductance function).
The PM2525 is out of production so far I know but can be bought used for "reasonable" price (about $200).
Christoph
Old 11th June 2002, 03:35 AM   #19
Ricren is offline Ricren
Ricren's Avatar
Default Thanks for the input- now LRC?
FOlks.
First at all, thanks a lot for taking valuable time to answer my question.
After receiving such a strong endorsment for the old 77 from Eric and Bernhard, I did some repairing work on it and is now working . This unit survived a drop from a two story building and a lot of abuse since it was bought in 1979. Still works great.
Other: I did some serching at the Fluke site and they offer some interesting new models like the one Dorkus pointed, the 177. But from the specs I understand that the capacitance test range is restricted from 1 nf to several MF. Also, four digits would be great. The 189 have a range of .001 to several MF,but they are expensive.
So now that the 77 is alive and noticing that their new cousins are great but expensive, I'll try to buy some device to measure Cs and inductance.. I have some multichannel active crosovers to buid and that means good matching.
So, any suggestion for a decent LCR meter ?-Portable or bench. Not expensive1
Tks.
Ricren
PS: Hey Phil, those test probes from Pomona are great!
Old 11th June 2002, 03:16 PM   #20
dice45 is offline dice45  Germany
Default LCR and stuff
Ricren and all,
of course i use analogue MM. The Geortz/Metrawatt UNIgor i have is a very precise and convincing instrument and it must have cost more than my Fluke 123 when it was new and modern. I would not like to miss it.
THe Fluke 123 i do use for rough capacitance guesstimations, but only if i am too lazy to use my LCR bridge.
For LCR i would not use any digital meter.
I once owned a digital Escort LCR meter, do not remember the model#, sells for about 260.- , just fine for electrolytics and medium size caps. But i found it was handing out arbitrary results concerning Q/damping, depending on the selected measuring range, with capacitors and arbitrary inductance results, too, not too reproducable, so i sold it. The instrument was not faulty, it was a flawed design. But similar stuff i have experinced more-or-less from any instrument claiming to be an LCR meter.
For LCR measurements, i use a bridge. An ESI 250 DE impedance bridge, to be specific. I bought it form the local surplus dealer for comparatively huge money, 250.- but it is worth every cent. Incredibly accurate, versatile, reproducable, yes, even neat and handy. Huge measuring range, i get reproducable results in the single pF range as well as in the 100F range.
It came from military service, those folks can afford to use non-junk only .
For capacitor quality investigations below 1.1 F i use a Rohde & Schwarz dielectric test bridge, measuring the tangens delta (loss factor) at a chosen test frequency.
What i am still searching for: a voltmeter with infinite input impedance. Useful for measuring dielectric absorption. I know where a certain HP instrument is for sale, just cannot afford it currently.
Bernhard
Multimeter recommendations?Hide this!Advertise here!
Multimeter??????? genmin Equipment & Tools 4 22nd January 2009 11:30 PM
Multimeter fauxpas Tubes / Valves 38 24th December 2007 12:28 AM
What to look for in a multimeter specialx Equipment & Tools 5 4th October 2002 04:04 AM
