Equipment & Tools From test equipment to hand tools
Possible to weld metal with small butane torches????
Old 8th July 2004, 09:11 AM   #1
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
Question Possible to weld metal with small butane torches????
Hey guys, I was wondering if you can do light use welding of like steel and aluminum with these hand held butane torches. They say they can get up to and over 2000*F
Like these little things;
Old 8th July 2004, 10:11 AM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Most likely not. Temperature isn't everything, you also need to consider the energy the torch is able to put out. If it doesn't put out enough energy, the material you're welding will dissipate so much heat that the torch is unable to heat it enough. Look for something a little heavier
/U.
Old 8th July 2004, 12:06 PM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Ya. It can't even weld your fingers, and skin is really weak stuff when it comes to comparisons with metal. Seriously, those POC's have less heat than a candle.
Note that with a burner like THIS, it only gets maybe orange hot (1600-1700F) in free air, despite the prodigious amount of power output. Putting up some firebricks to hold the heat in can bring that to melt steel but the heat is too diffuse to actually weld a joint or anything.
So. For one you need a temperature higher than the melting point of around 3,000°F. Acetylene and pure oxygen burns upwards of 5,000 degrees, it's very hot stuff. Plasma in the form of a high-current arc has even more, the low end being around 10,000°F. Put 100 amps at about 20V into a space that small and you'll melt anything.
Heh. This post looks more like describing how to build something, without giving anywhere near enough details to do so, than just telling you why it won't work. S'pose I *am* tired yet...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 8th July 2004, 12:31 PM   #4
karma is offline karma  Canada
karma's Avatar
mine is older but you can braze weld with it and more cost me $100. i have had it for 5 year's now it's worth the money
http://www.bernzomatic.com/bernzomat...equestid=87320
Old 8th July 2004, 12:42 PM   #5
karma's Avatar
here it is there high end model
Old 8th July 2004, 01:20 PM   #6
Magura is offline Magura  Denmark
Magura's Avatar
To join aluminium you can use a torch like that for fusion welding. Technoweld have some little kits for that purpose, that comes with a good beginners manual.
Ive been building bicycle frames like that once, just to see what happened....and it worked rather well.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 8th July 2004, 03:36 PM   #7
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
actually I have found welding with a standard torch on aluminium difficult...hold it too long and it'll burn through the metal...duhz...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 8th July 2004, 05:10 PM   #8
Sch3mat1c's Avatar
Oh, I was going to add, oxy-acetylene (O/A) can weld steel but oxypropane won't work. I don't know why, I'm not a weldor. Works fine for cutting though. AFAIK, anything with enough concentrated power (arc, O/A, O/P I guess... possibly oxybutane to keep it on topic ) can do aluminum. As I recall, you need special fluxes for gas but arc is done on AC and that has a fluxing effect. Not to mention being under an inert gas.
Tim
Old 8th July 2004, 08:54 PM   #9
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Oxy acetylene is too hot for aluminum. You need oxy hydrogen. Or better yet mig. Hobart sells a small mig setup for $650.00. you can also use it for steel up to 3/16" in single pass.
Stick with screws and rivits for aluminum unless you want to spend big bucks and lots of time learning.
Old 8th July 2004, 09:15 PM   #10
karma's Avatar
with my torch metal's fine aluminum no. i didnt say anything about that lol. it would burn a nice hole in it
yes u could if it's metal and hot enuff
aluminum? brian has a point use screw's. or pay $650 ouch
http://www.millerwelds.com/education/library.html
Possible to weld metal with small butane torches????Hide this!Advertise here!
Metal Oxide vs flamme proof vs metal film ostie01 Parts 28 26th June 2006 07:38 AM
small metal boxed goodmans speakers baggins Multi-Way 0 30th April 2006 12:00 PM
J-B Weld for repairing lifted pad philibuster Everything Else 3 5th November 2005 12:48 PM
FS : Weller Butane Soldering Iron pho_boi Swap Meet 0 8th January 2005 11:32 AM
