Equipment & Tools From test equipment to hand tools
Analyser recommendations
Old 14th June 2018, 07:34 PM   #31
jsantoro is offline jsantoro  United States
I've downsized and it's just too big for how often I use it.
Old 14th June 2018, 07:35 PM   #32
anatech is offline anatech  Canada
anatech's Avatar
If I was anywhere near you, I'd be interested. It is a nice signal analyser.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 17th July 2018, 05:04 PM   #33
MrSlim is offline MrSlim  Canada
Originally Posted by lisoformio View Post
Right Mark (http://audio.rightmark.org) + E-MU 0202/0204.
I just dug up a 0204 I had kicking around and installed the driver from the CD onto my Windows 7 laptop, and RMAA crashed/hung the system when I tried it.
Can you let me know what settings you use (in case it's as simple as that)?
Old 18th July 2018, 04:54 AM   #34
1audio is offline 1audio  United States
There was stuff on the RMAA site on getting RMAA working with The EMU stuff I think. In any case start by making sure the card is working both record and playback in windows. Then try ASIO. RMAA usually doesn't crash things but I noticed the latest version is buggy. Try an older version once you know the card itself is working.
Demian Martin
Product Design Services
Old 18th July 2018, 05:46 AM   #35
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Originally Posted by Audio1Man View Post
I repair, service & sell used Audio Precision test system and APIB USB Interface adapters to work with XP through Win10. I get many systems in my shop that were from EBay and many were used in a production line and do require many new parts so they can meet the SPECIFICATIONS. The cost is typical investment is $2500 or more and this typical leaves the hobbyist to use other equipment. The QA401 and other analyzers are good alternative to the hobbyist who typically have limited budgets. Duke
Duke, so if I understand correctly, I buy a "used" AP systems on fleaBay for for $2500 USD. Then I find out scheisse, it doesn't work right. Dummy me, bought something that had it's life wrung out of it in a production environment. So I send it off to get fixed and want it in SPECIFICATION. why else have one, right? From what you say, your time and effort can easily exceed $2500UDS to fix it so runs right and meets SPECIFICATION and will last a bit.
And so that good deal on fleabay...and repairs...plus shipping, extra stuff runs over $5000USD pretty quickly.
O course you know I concur, being a hobbiest, $5000USD plus for one piece of gear, yeah looking for other equipment.
Thanks Duke, sometimes I just have to run it by me again to make sure that I understand.
-- Sync
Old 18th July 2018, 11:48 AM   #36
Thanks, I think the 0204 is hooped.. I tried even playing a test sound to it from the control panel and it hung the computer..
Old 18th July 2018, 01:54 PM   #37
Do you have enough power for the 0204? Are you using the external supply?
Demian Martin
Old 18th July 2018, 03:42 PM   #38
Hm.. that's a good point. No, I was just trying to power it from the USB port on the laptop. I have a Y cable for external power but it's got a Mini connector on it.. I may have to hack it or find an adapter for it, since the 0204 has a USB Type B connector on it..
Old 19th July 2018, 05:20 AM   #39
I thought the 0204 had support for an external supply like the 0404 and the tracker pre. Also you could try it in a different system. Make sure Windows does not try to load its native (and buggy) UAC 2 driver.
Demian Martin
Old 20th July 2018, 09:47 PM   #40
Audio1Man is offline Audio1Man  United States
Duke Aguiar Design Services
Hi Sync
Not all EBay systems are bad. You just need to know that you may not get a SUPER GREAT WORKING SYSTEM. The systems that Marshall (I service his systems) & I sell are good working units. The systems that come from a production environment usually have relay, fan, and connector problems. My biggest repair was well under $1000. Some of the systems that I have serviced were poorly repaired patch jobs.
Duke
Analyser recommendationsHide this!Advertise here!
Audio Analyser using a uC ashok Solid State 1 26th January 2009 12:23 PM
Visual Analyser, LX.1690 Analyser kit and other MAGICS!!! fotios Software Tools 8 18th March 2008 01:48 AM
Visual Analyser & Nuova Elletronica LX.1690 KIT Oscilloscope + Spectrum Analyser fotios Solid State 25 9th March 2008 07:35 PM
PC O'scope/analyser percy Solid State 15 25th August 2005 02:03 PM
