Equipment & Tools From test equipment to hand tools
The Bode-100 thread
The Bode-100 thread
Old 8th August 2018, 12:24 PM   #51
jackinnj is offline jackinnj  United States
jackinnj's Avatar
The Bode-100 thread
Follow George's advice, keep cranking the voltage until you see smoke!
Old 8th August 2018, 11:16 PM   #52
jackinnj's Avatar
The Bode-100 thread
Looking at a TI application note, I got some THS3121 -- they are good to drive 400mA. The THS3121 does not have "Power-Down" or "Ref" so always consumes 7mA:
Old 9th August 2018, 10:34 PM   #53
jackinnj's Avatar
The Bode-100 thread
Since the THS3121 can drive a lot of current, and has a high slew rate, maybe it can be used as a line injector with a pair of MOSFETs: (This hasn't been built yet)
Old 10th August 2018, 06:09 PM   #54
DualTriode is online now DualTriode  United States
Hello,
It looks like this idea can kick butt. However I am a bit concerned about the the transfer curve of the 100uf capacitor.
Thanks DT
Old 10th August 2018, 08:09 PM   #55
jackinnj's Avatar
The Bode-100 thread
Can be normalized with the Bode-100 calibration regimen. Here's some actual results with the THS3121 (using a 1,000uF Nichicon). It's down 2.4dB@10MHz. I modified the evaluation module with a little help from the Dremel tool.
Old 10th August 2018, 10:50 PM   #56
Jack,
Very nice results.
DT
Old Today, 11:20 PM   #57
Default Smoke On The Water
Hello,
Mostly staying indoors with the HEPA filter. California and Oregon are on fire. Look at this NOAA HRRR model of the smoke going past New Jersey.
Loop
Take a look at this VAC 250F core with most of 100 turns of primary and secondary coils made of solid strand silver plated 20 AWG wire with 600V insulation.
The idea here is a core that is less permeability than the B-Wit 100 core to allow much larger asymmetrical current, several 10ís of ma without saturation is the plan. Not yet tested.
Low frequency response appears to be okay. HF looks possibly usable to 3 or 4 megs.
See the attached frequency and phase plot plus photo.
Thanks DT
The Bode-100 threadHide this!Advertise here!
How to change thread title or delete thread in Swap Meet tubesguy Forum Problems 3 11th March 2017 02:32 PM
Some LM317 Bode Plots jackinnj Power Supplies 15 6th September 2012 03:48 PM
Power Supply Bode plot - a "how to" video jackinnj Power Supplies 6 25th February 2012 10:11 PM
Obtaining Bode plots for SMPS feedback loop eem2am Power Supplies 5 22nd October 2011 09:00 PM
Hilbert Bode - An old topic but perhaps a new question JMB Multi-Way 5 23rd September 2011 09:32 PM
