Equipment & Tools From test equipment to hand tools
Goodwill Instek digital oscilloscope
Old 1st June 2018, 10:35 AM   #1
hooman is offline hooman  Iran
hooman's Avatar
Default Goodwill Instek digital oscilloscope
if you are in repair amp or tray to build nice amp and other like preamp ...you should have good oscope . digital oscilloscope can help see and studying on signal .we inject signal to input and see result on small color tft.
after buy new one you need time to learn how it works and how protect this oscop ?
i used gds-122 frome goodwill instek. 6 weeks before when i pushed power key ...i heard noise from inside and became hot
iranaudiotube.blogfa.com
1979.....i lost everything
Old 1st June 2018, 11:01 AM   #2
hooman's Avatar
i disconnect battery as fast .
Old 1st June 2018, 11:28 AM   #3
hooman's Avatar
i found one 8 pin smd mosfet on goodwill oscope pcb.this is output of series regulator circuit .if this mosfet is damaged complete voltage of battery goes to 3.3 vcc line
there is no fuse and zener .
please look at the circuit for ovp and protect other parts. 16 v zener can protect 12 v lin .
for saving 3.3 v ve can use 4.1 v zener .
Old 1st June 2018, 12:20 PM   #4
hooman's Avatar
suppose you have transistor radio with battery power.if output transistor damage and no sound in speaker .there is one question.how transistor was damaged?
quality of transistor ....?
kind of music?
kind of battery?
life of transistor ?
Old 5th June 2018, 07:11 AM   #5
Mooly's Avatar
hooman you have reported this thread five time now. The title has been changed from goodwill instek digital scope to Goodwill Instek digital oscilloscope as you asked.
Old 5th June 2018, 09:07 AM   #6
hooman's Avatar
thanks ....
yes i asked for changing title .thanks
Old 6th June 2018, 05:39 AM   #7
hooman's Avatar
goodwill used in gds-122 fpga ic from exlinx.
Spartan-6 FPGA DC Characteristics
89
Spartan-6 FPGA Data Sheet:
DC and Switching Characteristics
VCCINT Internal supply voltage relative to GND 0.5 to 1.32 V
VCCAUX Auxiliary supply voltage relative to GND 0.5 to 3.75 V
VCCO Output drivers supply voltage relative to GND 0.5 to 3.75 V
VBATT Key memory battery backup supply (LX75, LX75T, LX100, LX100T, LX150, and LX150T only) 0.5 to 4.05 V
VFS
after shorting mosfet in series regulator .... 7.5 v of battery damaged the fpga ic .....and getting hot very quickly.
Old 11th June 2018, 12:41 AM   #8
1audio is offline 1audio  United States
Its toast and replacing it will be a major challenge without the special equipment needed.
Demian Martin
Product Design Services
Old 17th June 2018, 03:02 AM   #9
hooman's Avatar
thanks for replay but i am working in sony service and can replace this kind ic simply but good will never answer to me .i send this oscop to goodwill service center in my country .they can just changing battery
repair by component is true service .
there is risk for digital oscope after warranty period if buy from company like goodwill.
Old 28th June 2018, 12:29 PM   #10
hooman's Avatar
main board of gds-122 goodwill digital oscop .
Goodwill Instek digital oscilloscopeHide this!Advertise here!
Digital Oscilloscope? MattNes Equipment & Tools 67 Today 09:51 AM
digital oscilloscope group buy cyclecamper Group Buys 40 22nd June 2014 03:51 AM
Help selecting GW Instek Analog Oscilloscope sameerdhiman Equipment & Tools 5 28th December 2010 10:18 PM
FS: Instek DSO Oscilloscope, 150MHz Boris_The_Blade Swap Meet 1 12th June 2010 07:53 PM
Digital Oscilloscope - DSO USB ccschua Parts 0 22nd May 2009 09:19 AM
