Equipment & Tools From test equipment to hand tools
Measuring base spreading resistance
Old 7th April 2018, 12:58 PM   #31
Mark Johnson is online now Mark Johnson  United States
Mark Johnson's Avatar
It costs less than GBP 1,00 to purchase one. Now you can measure Vcesat at a variety of currents and a variety of temperatures.
Old 7th April 2018, 02:12 PM   #32
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Set the Vertical knob of your Tektronix 576 to "StepGen", the Horizontal knob to Collector and the Terminal Selector to "Emitter Grounded" and the vertical axis will display Ib, the horizontal axis Vce
(Unfortunately, the 576 doesn't give logarithmic results!)
Old 7th April 2018, 06:53 PM   #33
jackinnj's Avatar
Originally Posted by Maxwell3 View Post
This is cool, thanks for doing all the look-up!
Can you use the Excel option to label each point with the transistor number?
It would be good to understand what is the difference between transistors that have vce(sat) near 0.01V and very low noise vs. the ones that have vcesat of 0.005V but more noise.
I labeled the datapoints in Photoshop.
Anyone, feel free to provide better Vce(sat) numbers.
Old 8th April 2018, 02:35 AM   #34
Maxwell3 is offline Maxwell3
Thanks! I looked at more specific examples. For example 2sd2653 and 2sb1690 clearly have Vce(sat) of less than 10 mV, while 2sc3601 and 2sc3955 have Vce(sat) of about 0.1V. Yet the noise of the first pair is a factor of 2 higher than the noise of the second pair. So, while low Vce(sat) seems to contribute to giving a low-noise transistor, its not the only necessary ingredient.
Perhaps someone can stare at the examples of these datasheets and identify another reason why some transistors might be better than others.
I am going to get some PBSS4021nz transistors, which have Vce(sat) of less than 1 mV, the lowest I could find, and try to measure their noise. I haven't done such measurements before, so it may take me some time to setup the amplifier circuit. If anyone already has a setup to measure the noise, feel free to beat me to it.
Old 8th April 2018, 11:23 AM   #35
jackinnj's Avatar
... less than 1 mV, the lowest I could find, and try to measure their noise. I haven't done such measurements before, so it may take me some time to setup the amplifier circuit. If anyone already has a setup to measure the noise, feel free to beat me to it.
You just went "down the Rabbit hole, Alice".
Measuring base spreading resistanceHide this!Advertise here!
Measuring Ultra-high resistance AndrewT Equipment & Tools 7 30th April 2015 06:29 PM
Measuring resistance while circuit is turned on HiFiNutNut Everything Else 5 12th January 2009 02:06 AM
„New“ Pentode – measuring resistance between grids G2 and G3 – any idea? MRupp Tubes / Valves 5 5th January 2008 06:24 PM
Measuring resistance for T/S parameter calculations liasom Multi-Way 11 13th June 2007 11:40 AM
