Equipment & Tools From test equipment to hand tools
Tips for solder sucker?
Old 21st February 2018, 02:10 PM   #1
bugbear is offline bugbear  United Kingdom
Default Tips for solder sucker?
My solder sucker tip has finally melted back to the point where it doesn't work so well.
I bought it cheap, and it's unbranded. Heavy though, and nicely made.
I want to buy new tips, which means the new tips need to screw on to the old body.
I have measured the old tip thread as well as I can. The thread pitch is only 5 turns, so very hard to measure accurately.
Outside diameter (OD) 0.7215" or 18.32mm
Pitch(metric): either 0.75mm or 0.8mm
Pitch(imp): 30 or 32 TPI
Can anybody match this up?
BugBear
Old 21st February 2018, 02:22 PM   #2
Enzo is online now Enzo  United States
How about a photo so we have some idea what you are trying to match?
Old 21st February 2018, 02:33 PM   #3
This is the sort of pump
| RS Pro 190mm Standard Aluminium Solder Sucker with PTFE Nozzle |
Tips are similar to this:
| RS Pro Desoldering Nozzle for use with Abeco DSG PRM Desoldering Gun |
BugBear
Old 21st February 2018, 11:13 PM   #4
Do those not fit yours?
I used to buy those metal solder suckers at surplus. I found the sucker itself was less expensive than the replacement tips.
Old 22nd February 2018, 07:55 AM   #5
My slurper...
Click the image to open in full size.Click the image to open in full size.sucker by plybench, on Flickr
BugBear
Old 22nd February 2018, 08:40 AM   #6
stratus46 is offline stratus46  United States
Originally Posted by bugbear View Post
My slurper...
BugBear
I've used little ones like that and the main issue I had with it is getting a seal so it actually extracts the solder. Instead I use the old Edsyn like this
The Original Deluxe SOLDAPULLT: EDSYN Inc.
Similar but bigger. It moves enough air that if you _don't_ have the best seal it clears the hole anyway. For a while I was using one from DigiKey
https://www.digikey.com/product-deta...K412-ND/243483
It LOOKS the same and works the same UNTIL IT BREAKS internally. I went through 3 or 4 in a few months (we bought a bunch at work). I'm back to the Edsyn and have no problems. These gadgets need to be kept clean and lubed. The lubricant is silicone grease without zinc oxide in other words, clear heatsink grease. I found that swimming pool O ring seal grease works as well, cost a little less and is much easier to find.
G
Old 22nd February 2018, 10:18 AM   #7
Samsara is offline Samsara  France
Hello.
More expensive but very usefull, iron desoldering
110V/220V Desoldering Gun Electric absorb gun S 993A Electric Vacuum Desoldering Pump Solder Sucker Gun 100W -in Electric Soldering Irons from Tools on Aliexpress.com | Alibaba Group
Old 22nd February 2018, 11:08 AM   #8
levistubby is offline levistubby  United Kingdom
My sucker is similar to the one pictured and is probably 20 years old and the tip shows no signs of melting at all. Some tips must be made of better material than others.
Old 22nd February 2018, 11:34 AM   #9
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Slip a short length of silicone tubing over the teflon tip.
Seals perfectly to pcb, replace as required.
Dan.
Old 23rd February 2018, 03:09 AM   #10
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
Dan.
You can put a long bit on and pull it down as it wears away.
It is a good tip saver.
Tips for solder sucker?Hide this!Advertise here!
FS: Hakko N454-T-2C fine solder tips Andersonix Swap Meet 7 27th February 2014 07:51 PM
How To Solder Tips and Tricks Eddiegnz1 Tubes / Valves 21 20th December 2013 09:52 AM
Solder bridge clearing tips - LM3875 nemonis Chip Amps 30 3rd December 2011 07:12 PM
Any tricks to desoldering using a cheapo solder sucker? Glowbug Construction Tips 20 2nd June 2010 09:31 PM
Any tips for snap in type caps to replace solder lug cans? mountainhick Parts 2 10th February 2010 11:26 PM
