Equipment & Tools From test equipment to hand tools
DiAna, a software Distortion Analyzer
Old 13th June 2018, 07:17 PM   #521
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default Version 1.15.6 available
@Kean,
Yes I've changed something. In the new version (just uploaded) I've changed the full screen mode again. Hope it will finally work (under Wine).
As for calibration, indeed there was an error. I put the (sqrt)2 fiddle factor at the wrong place and at the wrong time.
Also added a new feature: Auto ranging and full scale mode of the vertical oscilloscope axis. Right click on the 5th status bar pane to select one (see fig.). With auto-ranging you scan see and playback the whistle2.wav file more better. You also can get a spectrum of this noisy file if you disable the outlier check: Set OutlierTol=1000 in the ini file.
To all: Always delete the old ini file when using a new version of DiAna.
E.
http://www.data-odyssey.nl/
Old 13th June 2018, 07:22 PM   #522
Originally Posted by keantoken View Post
In V51.6, fullscreen seems to work better now than it did before V51.5.
Better or perfect?
But how about the issues with simulation variable? No more crashes?
Cheers, E.
Old 13th June 2018, 08:01 PM   #523
Originally Posted by 1audio View Post
Edmund-
The ASIO works with Lynx and RME. It doesn't work with EMU or the QuantAsylum. Something about unrecognized ASIO format. I'll capture the details if that will help.
Hi Demian,
Did you see a format code (see fig.)?
E.
Old 13th June 2018, 08:49 PM   #524
keantoken is offline keantoken  United States
keantoken's Avatar
I can't find a bug with the fullscreen button yet. The only strange thing is that when maximized, I can still resize the window by clicking the lower right corner. Then it seems to follow some internal logic to reset the button states to something logical, but it doesn't crash.
All settings in the simulation menu seem to work, and have for a while now. Although sometimes when I set the amplitude noise to 1db or 6db for instance it will give a "memory error" in the lower right.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 13th June 2018, 10:22 PM   #525
Default Wine issues
Great!
That's normal (though not intentional). Blame MS and not me, as they forced me to limit the full screen to the so called "work area" (see post 516), otherwise the taskbar at the bottom of the screen will be overwritten (and invisible). As it isn't really full screen (just almost), that's the reason why you can still resize the window.
Done on purpose.
Great! So it payed off to rewrite a large part of the preferences code.
Hmm .. weird (I never saw it). Maybe you got this error because some table wasn't initialized in time. Remember, DiAna is a multi-multi-threaded program. So it isn't that easy get all things synchronized.
Then there was another issue:
>"Also I discovered if you click file and then click one of the other menu buttons, it will bring up the file selector. Is this intentional?"
Of course, that's not intentional. Does it still persist in the new version?
When all these minor bugs are eliminated (also wrt calibration), we can finally start the real work: Getting ASIO working under Wine.
E.
Old 14th June 2018, 06:56 AM   #526
I can't find a bug with the fullscreen button yet. The only strange thing is that when maximized, I can still resize the window by clicking the lower right corner. [...]
If you think it's useful, I can omit this "feature".
Old 14th June 2018, 06:59 AM   #527
keantoken's Avatar
Probably best to just leave it alone. People will expect to be able to resize if they can see the window border so you would be trading one oddity for a different oddity.
Old 14th June 2018, 07:55 AM   #528
Default Buggy windows
Actually, it isn't an oddity at all. It's weird and stupid that you can't resize a 'regular' window when in its maximized state. That's buggy and I don't see any reason to emulate that bug in DiAna.
E.
Old 21st June 2018, 10:59 AM   #529
McLanz is offline McLanz  Germany
McLanz's Avatar
Hi, I'm trying to optimize my Nelson Pass DIY F5 amp for distortion. (Its the little P3 pot thing - the pot is paralled over the input JFets source resistors).
I need to see the residual distortion wave form on my osti.
I understand your software could help me instead of buying a distortion analyzer - which is at least in Germany still not affordable even in old used condition.
My question to already expirienced users of Diana: Did cheaper ASIO compatible soundcards work too?
My goal is to spend not that much, stay under 100Euros if possible. (Its purely for the F5 amp)
Thanks for sharing your expirience- Jochen
Old 21st June 2018, 12:21 PM   #530
Hi Jochen,
Cheaper sound cards do work, but, due to the distortion of the sound card itself, the measurement floor might not low enough to measure the distortion of the amplifier.
The cheapest solution (0 euro) is to use the on board sound chip of your PC and install ASIO4ALL to make it ASIO compatible. On my PC I get a measurement floor of -95dB. I guess not low enough to measure the THD of an F5 amp.
E.
DiAna, a software Distortion AnalyzerHide this!Advertise here!
Analyzer Software Overview dennis h Equipment & Tools 153 10th December 2017 07:40 AM
Distortion analyzer troystg Equipment & Tools 5 7th December 2016 06:11 AM
True RTA analyzer software JAY X Equipment & Tools 5 18th October 2016 01:29 PM
Spectrum Analyzer software recommendations head_unit PC Based 8 22nd January 2012 06:39 AM
HP8903B Audio Analyzer Software Conrad Hoffman Equipment & Tools 11 1st June 2010 01:21 PM
