Equipment & Tools From test equipment to hand tools
DiAna, a software Distortion Analyzer
Old 7th December 2017, 02:26 AM   #31
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Does it work with ASIO4ALL? Or with certain cards and ASIO driver from manufacturer?
Failed to wait for this SW and sold my Lynx II
Old 7th December 2017, 02:49 AM   #32
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default ASIO4ALL
Hi Dimitri,
Yes, it works also with ASIO4ALL (at least on my PC and on the one of my GF, using the on board sound thingy), though initialization might be a bit tricky and fickle. So don't get desperate when it doesn't run immediately during a first try.
Did you sold your Lynx because I was too late with DiAna? If so, I'm really sorry.
Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het lichtů(H.M. van Randwijk)
Old 7th December 2017, 03:09 AM   #33
kannan_s is online now kannan_s  United States
Send a message via Yahoo to kannan_s
same issue - RTX 6001 uses Asio control panel - does not initialize ADC. error 108 - also new warning Close Asio control panel!
Old 7th December 2017, 03:43 AM   #34
dimitri's Avatar
Hi Edmond,
A few hints to get started:
First set Mode to "Read from ADC (...)"
Then initialize the sound card, go to 'Preferences' -> 'Sound Card'
It looks that internal sound card is recognized by ASIO4all but where is "Read from ADC"?
Thank you
Old 7th December 2017, 08:49 AM   #35
Originally Posted by Edmond Stuart View Post
What kind of error msg. Does it show an error code?
Your main site works perfectly.
Did so some years ago when I first read most of what you publish. Need to read again, there are so many good bits in there that often get forgotten about.
regards Andrew T.
Old 7th December 2017, 09:32 AM   #36
TNT is online now TNT  Sweden
If i where to use a software package for serious development I would require a type test verification record with specified tests and setup conditions incl. traceable references for the used verification equipment.
Can you provide this?
More distortion to the people!
Old 7th December 2017, 12:04 PM   #37
Thank you for your kind words.
Cheers, E.
Old 7th December 2017, 12:08 PM   #38
Originally Posted by dimitri View Post
Hi Edmond,
Thank you
Hi Dimitri,
That was a typo, my apologies. It should be: "Read from file m(.....)" (in the "Mode" pull down menu).
BTW, did you hit the ASIO Control Panel button?
Cheers, E.
Old 7th December 2017, 01:27 PM   #39
Hi kannan,
I'm afraid the ASIO control panel (ACP) is making troubles again. You pushed that button again, didn't you?
This ACP is really a PITA, as every sound card provider implements it differently, because the specification from Steinberg for this item is rather vague. As a result, there exist no full proof method to determine whether the ACP has been closed (by clicking on the "OK" button inside the ACP window). Apparently, DiAna fails in this respect and sends a warning. But don't blame me. It is a serious omission in the ASIO specifications and not a bug in DiAna, or should I call it a "blameless bug"?
Anyhow DiAna needs to know the state of the ACP, otherwise, when you start an analysis, while the ACP is still open, it might crash.
Of course I could have prevented all these troubles if I had an RTX6001 to my disposal and test the software before "going public", but I missed the deadline to order one.
So, if you haven't give up yet, would you try to initialize the RTX6001 again, but now without touching that pesky ACP button at any time?
In the meantime I've disabled (grayed) the ACP button. However, if you really need it, you can enable it again by setting "AcpEnable" parameter in the ini file to a non zero value.
Cheers, E.
edit: Could you upload a picture of the ACP?
Old 7th December 2017, 01:31 PM   #40
It is meant for "serious development", but I'm afraid this package is not for you.
DiAna, a software Distortion AnalyzerHide this!Advertise here!
Analyzer Software Overview dennis h Equipment & Tools 153 Yesterday 08:40 AM
Distortion analyzer troystg Equipment & Tools 5 7th December 2016 07:11 AM
True RTA analyzer software JAY X Equipment & Tools 5 18th October 2016 02:29 PM
Spectrum Analyzer software recommendations head_unit PC Based 8 22nd January 2012 07:39 AM
HP8903B Audio Analyzer Software Conrad Hoffman Equipment & Tools 11 1st June 2010 02:21 PM
Copyright ©1999-2017 diyAudio
