Equipment & Tools From test equipment to hand tools
DiAna, a software Distortion Analyzer
Old 5th December 2017, 11:08 PM   #11
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default Hartley transform
Originally Posted by davada View Post
Edmond why did you choose the fast Hartley over Fourier?
Hi David,
Good question. Since we are dealing here with real-valued data (thus not complex), an FHT is more elegant and slightly faster than an FFT. For further reading, please see: https://www.embedded.com/design/conn...artley-Smartly
Cheers, E.
http://www.data-odyssey.nl/
Old 5th December 2017, 11:48 PM   #12
davada is offline davada  Canada
I have the transform code and I'm familiar with this site.
It's also easier to understand. I like that fact that it is the inverse of itself.
David.
Old 6th December 2017, 12:09 AM   #13
Default FHT vs FFT
And, opposed to an FFT, no ugly hassle to store real date in the space for imaginary stuff. That's what I dislike most about an FFT, totally malformed in order to accommodate only real data.
Old 6th December 2017, 02:03 AM   #14
bk856er is offline bk856er  United States
bk856er's Avatar
Originally Posted by Edmond Stuart View Post
The file itself can be downloaded at www.data-odyssey.nl/diana/ (not Index of /diana/)
and a few hints to get started can be found at: DiAna
Documentation and help files will come later.
Good luck.
Cheers, E.
Microsoft Security Essentials says the zip contains a virus and automatically deletes the file. This is a first for me. Safe or no?
BK
Old 6th December 2017, 02:39 AM   #15
kannan_s is offline kannan_s  United States
Send a message via Yahoo to kannan_s
same case for me too?
Old 6th December 2017, 03:15 AM   #16
Edmond try removing the .exe extension and re-zip.
Users can add the extension after DL.
Works for me when emailing exe's.
David.
Old 6th December 2017, 03:20 AM   #17
Have you played around with the Hilbert transform.
It's quite cool. One can generate the cosine of a signal. Make the other half for FFT.
David.
Old 6th December 2017, 06:18 AM   #18
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
The residual is obtained by subtracting a pure sine from the (coherent integrated) input signal.
But how do you determine the amplitude and the time / phase shift of the signal used to subtract?
[ audioroot.net | hifibau.ch ]
Old 6th December 2017, 01:15 PM   #19
Indeed, a good question. To do it right and accurately, it is far from easy. As for the fundamental, hundreds lines of code were needed to extract the frequency, phase, amplitude and offset from the data. How exactly I've done it, I won't tell you, sorry. But it is done as accurate as possible with an error rate in the order of 1E-6 to 1E-22, depending on the background noise, of course (as you know: 'garbage in, garbage out', which also applies in this case, alas).
Old 6th December 2017, 01:39 PM   #20
BK
It is a false positive as only two out of 60 virus scanners are wining about "not-a-virus:AdWare.Win32.Gamevance.gen", see list below (generated by virustotal.com). Anyhow, a virus or not, it's harmless.
Cheers, E.
DiAna, a software Distortion AnalyzerHide this!Advertise here!
Analyzer Software Overview dennis h Equipment & Tools 153 10th December 2017 07:40 AM
Distortion analyzer troystg Equipment & Tools 5 7th December 2016 06:11 AM
True RTA analyzer software JAY X Equipment & Tools 5 18th October 2016 01:29 PM
Spectrum Analyzer software recommendations head_unit PC Based 8 22nd January 2012 06:39 AM
HP8903B Audio Analyzer Software Conrad Hoffman Equipment & Tools 11 1st June 2010 01:21 PM
