Equipment & Tools From test equipment to hand tools
Best method to clean soldering iron barrel
Old 26th November 2017, 03:09 AM   #1
Hogwild is offline Hogwild  Canada
Default Best method to clean soldering iron barrel
Hi friends:
I am quite familiar with keeping my Weller iron's tip in good shape. However, the barrel and nut have become rather oxidized and have a fair bit of that white residue on them. What is the proper method to clean those?
Old 26th November 2017, 03:18 AM   #2
HarryY is offline HarryY  United States
HarryY's Avatar
Steel wool or a wire brush should work.
Old 26th November 2017, 03:25 AM   #3
HarryY:
That's easy enough. It doesn't matter if you scratch the heck out of it? Is there a method that doesn't leave so many scratches?
Old 26th November 2017, 03:39 AM   #4
HarryY's Avatar
Fine steel wool should work.
I think l used a wire wheel on one of mine before with a lighter touch.
Old 26th November 2017, 04:26 AM   #5
Thanks Harry.
Old 26th November 2017, 05:04 AM   #6
Enzo is offline Enzo  United States
I'd grab a wire wheel and my Dremel before steel wool myself, but it is really the same thing to the iron.
Do you use a damp sponge to wipe the tip? If so, the white reside may just be mineral scale left from evaporating water on the thing.
I never worried about the cosmetics, they don't affect the heating. I have wire wheels in my Dremel selection of steel, brass, and even fiber. Pick a less aggressive brush if you like.
And replacement barrel/nut are readily available for not a lot of money - bright and new. I keep a spare one in my soldering dawer in case the one on the iron gets damaged.
Old 27th November 2017, 01:02 AM   #7
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
I bet that a few weeks after you have cleaned the barrel the tip end will become warn out enough that the tip starts falling out all the time.
You will then have no choice but to buy a new barrel like I had to a couple of years ago.
It cost about half the price of an element.
Old 27th November 2017, 01:27 AM   #8
HarryY's Avatar
The steel wool I'm talking about is fine steel wool like what's in an SOS pad.
Old 27th November 2017, 02:17 AM   #9
Refugee1's Avatar
The tip end wears out from inside over time so that it no longer holds the tip. It is the little lip at the tip end that eventually gives up and lets the tip fall right out.
Old 27th November 2017, 03:03 AM   #10
Conrad Hoffman is offline Conrad Hoffman  United States
A bit OCD aren't we? If it's stainless steel, use some Barkeeper's Friend on a wet paper towel. It contains oxalic acid and is quite effective.
I may be barking up the wrong tree, but at least I'm barking!
Best method to clean soldering iron barrelHide this!Advertise here!
Soldering iron 355F1 Equipment & Tools 2 18th January 2017 10:19 PM
New soldering iron cyto Equipment & Tools 1 6th November 2016 01:56 AM
Looking for a soldering iron cent88 Equipment & Tools 9 30th January 2011 09:55 PM
toner/iron method problem hernanstafe Everything Else 38 5th April 2007 04:28 AM
