Equipment & Tools From test equipment to hand tools
What tool do you wish you had bought sooner?
Old 7th November 2017, 07:10 PM   #11
Jonathan Bright is offline Jonathan Bright  Australia
On reflection it would have to be GOOD QUALITY stuff. Its the same with everything from soldering irons to garden tools.....
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 7th November 2017, 07:14 PM   #12
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Diamond wheel 3 stage knife sharpener.
planet10 needs your help:
Let's help Ruth and Dave
Old 7th November 2017, 08:27 PM   #13
AcoustatAnswerMan is offline AcoustatAnswerMan  United States
AcoustatAnswerMan's Avatar
A 13-foot hose for my shop vacuum, purchased when the original 7-footer gave up the ghost.
An rechargeable LED headlamp. How did I ever live without this handy device?
A fiberglass scratch brush, wonderful for cleaning corrosion/oxidation from old parts prior to soldering.
Old 7th November 2017, 09:46 PM   #14
Speakerholic
Cal Weldon's Avatar
Fully agreed.
If you mean the lamp you wear on your head, again, fully agreed.
And for reaching that spot between your shoulder blades when your wife, letter opener, or chop stick is nowhere to be found.
Old 7th November 2017, 10:26 PM   #15
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
My table saw was a big step up. Gotta have it for speaker boxes and cutting aluminum sheet for enclosures.
And I thought I was the only one crazy enough to cut sheet aluminum on a table saw. My shop teacher about had a cow when I showed him these pictures.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 7th November 2017, 10:31 PM   #16
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
stereo microscope
Old 7th November 2017, 10:31 PM   #17
chrisb is offline chrisb
George - a higher tooth count blade would have made a cleaner and safer cut, but shop teacher would still cringe - can you remember if he had all his fingers intact?
like my mind, this space intentionally blank
Old 7th November 2017, 11:10 PM   #18
Pano is offline Pano  United States
Pano's Avatar
He's having a cow because you are using the rip fence and the miter gauge at the same time!
A good table saw is a thing of joy. I have used mine to cut brass.
Take the Speaker Voltage Test!
Old 8th November 2017, 02:09 AM   #19
He was missing about 1/2 inch of his middle finger from a construction site accident when he was in high school in Kentucky.
I whacked a sliver off the end of my pinky trying to one hand a hedge trimmer while up on a ladder. It could have been worse, and most of it grew back.
I had a better blade for the purpose, but it was an expensive blade for hardwood....I just decided to use the crummy blade that came with the saw.
Old 8th November 2017, 02:15 AM   #20
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Forgot to mention "Bo-shield" -- pick it up in the bike shop -- invented by Boeing --
wonderful for preventing rust -- i had to keep my contractor saw in the garage and this abated the rust on the cast iron table over winter.
What tool do you wish you had bought sooner?Hide this!Advertise here!
WOW should of done this sooner johnmik Equipment & Tools 18 4th April 2012 08:43 AM
large heatsink will be available by april or sooner barrredboss Heatsink USA 52 22nd June 2011 02:48 AM
should have come here sooner vasyachkin Introductions 4 1st January 2008 12:07 PM
Sorry for not introducing myself sooner. walker Introductions 2 2nd February 2002 03:46 AM
