Equipment & Tools From test equipment to hand tools
Started My Transistor Tester
Old 12th November 2017, 12:45 AM   #11
MadInventor is offline MadInventor  United States
Originally Posted by nigelwright7557 View Post
Its hard to get all the functionality into one system.
That is one reason why I'm looking at a higher current version for power devices.
MI
Smoke........ahhh...crap!
Old 12th November 2017, 04:31 AM   #12
anatech is online now anatech  Canada
anatech's Avatar
The problem with high current is that you generate heat everywhere. Connections become very important and voltage drops generated by the high current are big sources of error. This is true even if the test is a pulse type (except heat is less of an issue).
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 12th November 2017, 09:04 PM   #13
-Chris
Chris,
Like they say in the movies, I got to try. Found a 300 mA buffer for drive and a high voltage opamp. Probably will not use DMosfet current limiting, resistor plus fuse instead. Will tailor for 2-2.5 A max. .25 A/V current sense. Have an idea about mounting heatsink with TO-3 and terminal block for TO-3P-247 on top of pcb and configure with jumpers instead of switches.
MI
Old 12th November 2017, 11:37 PM   #14
anatech's Avatar
Hi MI,
That is more than fair enough. At least you are moving ahead with these thoughts in mind.
-Chris
Started My Transistor TesterHide this!Advertise here!
Transistor tester from Aliexpress ashok Equipment & Tools 8 30th May 2016 09:09 AM
Transistor tester circuit diagram ? srinath Equipment & Tools 2 6th June 2014 03:46 AM
useful transistor tester siliconray Equipment & Tools 0 25th November 2011 01:48 AM
Transistor tester wgpet74 Swap Meet 1 6th October 2011 10:24 AM
transistor tester janey Solid State 0 4th January 2002 02:44 PM
