Equipment & Tools From test equipment to hand tools
Amplifier Dummy Load for THD measurements / non-inductive?
Old 15th October 2017, 01:26 PM   #31
Zymorg is offline Zymorg  Germany
Just ordered a tpa6120 headphone amp module from china as well. It's so unbelivable cheap and has even the power supply on board (except for traffo).
Old 15th October 2017, 01:31 PM   #32
@Burnedfingers: Are they really non-inductive? What size of amps are you testing?
Old 15th October 2017, 02:06 PM   #33
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Among many other applications, I use dummy loads for amplifier slew rate testing. So I prefer them to remain noninductive all the way up into the dozens of megahertz when possible.
Old 15th October 2017, 03:21 PM   #34
1audio is offline 1audio  United States
Once you add cables all bets are off. If you have the right instrumentation you can characterize to whatever you need but its not cheap. Above a few KHz you really are best served with a vector network analyzer. Connecting with a cable then adds to the problem since the cable will be 50 Ohms or higher.
I'm away from my shop for another 2 weeks but I can plot the resistors to 3 GHz when I return if its of interest.
Slew rate into a resistive load is interesting. Do you sweep to 3% HD to find where the output departs from feedback control? How does capacitive loading affect the slew rate? Lots to explore.
Demian Martin
Product Design Services
Old 15th October 2017, 04:47 PM   #35
Nah, I just remove the input LPF and apply a fast risetime square wave whose amplitude is chosen to swing the output almost to clipping. Slew Rate =approx= deltaV/deltaT .
In the picture below, 35V / 320nsec = 109 Volts/usec
_
Amplifier Dummy Load for THD measurements / non-inductive?Hide this!Advertise here!
Adding a dummy load to prevent amp from being damaged by having no load? Joku Tubes / Valves 6 12th May 2015 07:27 AM
DDDumy Load, a versatile power dummy load tool dddac Equipment & Tools 6 14th January 2014 12:36 AM
Testing PKN XD2500 ClassD Amplifier On DUMMY Load. DjLeco Class D 9 22nd January 2013 05:07 PM
Amplifier Dummy Load Nichrome Wire Brycebw Solid State 13 25th March 2012 05:15 PM
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
