Equipment & Tools From test equipment to hand tools
In circuit capacitor testers advice please.
Old 11th October 2017, 08:09 PM   #11
kaputt is offline kaputt  Germany
kaputt's Avatar
Well, it does measure ESR. If the cap is shorted internally and passes DC it will cause problems but probably read awesome on the meter...
Oh boy, I live in the snake oil thread...
Old 11th October 2017, 08:42 PM   #12
soul music is offline soul music  United Kingdom
My partner was listening to the boombox when it failed. She told me it was working fine and suddenly there was a very loud buzz (which lasted about 1 second) that made her jump and then nothing (I would say there was still the hum that there always had been in the background though). Also my 9 year old son was fiddling about with the end of the jack lead that we use to play our tablets through via the aux input on the boombox. He was putting his fingers on the end of the lead causing a humming sound on the boombox. It was a few days after my son did this that the boombox failed, could this have done any damage?
Old 13th October 2017, 03:05 AM   #13
PedroDaGr8 is offline PedroDaGr8  United States
PedroDaGr8's Avatar
Originally Posted by soul music View Post
There is a hum from the speakers, I bought this boombox not working a few years ago on eBay with exactly the same symptoms it is having now and I had it repaired by a professional who unfortunately no longer does repairs. He replaced a cap on the audio board though I do not know if he did anything else to get it working, regarding testing caps in circuit here is the link to the YouTube video for the in circuit cap tester
YouTube
There are a lot of caps in this boombox and it really would be a time consuming job to remove them to test them.
While, the youtuber is not wrong exactly, most of the methods he mentions only work when the caps have been dead a LONG LONG time, most circuits start messing up much earlier than that.
As for testing in-circuit, the issues are as follows:
1) Most modern ESR meters will not turn on most traditional silicon devices. From the cheap multi-component testers on eBay, to the toys and low-end pieces like the MESR-1000 and Peak ESR reader, to the real LCRs like the Der EE DE-5000 (also sold by IET labs as the DE-5000 and 6000), unless you hit very specific capacitors (usually VERY VERY large), you will not trigger silicon devices.
2) Any circuit which has capacitors in parallel absolutely CANNOT be read, even by the in-circuit devices. It is physically impossible to measure them in circuit, you can only measure the parallel properties of all of the capacitors in that node of the circuit.
Keep in mind, a little trick that I know some do. You don't have to remove the capacitor entirely, just disconnect/lift one leg. That is good enough to break the circuit and get the measurement you need. Even better, you can do it with ANY ESR reader on the market period (for the most budget conscious, I advise the multi-component testers on eBay, for those wanting a real LCR I advise the DE-5000).
Old 13th October 2017, 07:28 PM   #14
Thanks for your very comprehensive answer. I assume it does not matter if the positive OR negative leg is lifted when testing a capacitor? Would a
Jingyan M6013 Digital Auto Ranging Capacitance Meter be good enough for a novice such as myself? I already have a multimeter but it does not test capacitors.
Old 13th October 2017, 08:17 PM   #15
Mooly's Avatar
That sounds more like a power output chip popping its clogs. Very loud buzz and then nothing... the buzz you still hear could be from the transformer.
Old 13th October 2017, 09:21 PM   #16
PedroDaGr8's Avatar
Correct, it doesn't matter which leg you lift, as long as you don't complete the circuit with the board.
No, that does not test ESR, it simply reads capacitance. Even at that, it does not do ti at a specific relevant frequency, making it useless for comparing to datashsets (capacitance for electrolytic is strongly frequency dependent). If you are just a simple hobbyist, then I would recommend something like this:
Amazon.com: Quimat Multifunctional Transistor Tester with LCD GM328,DIY Diode Capacitance ESR Voltage Frequency Meter PWM Square Wave Signal Generator: Industrial & Scientific
It gets you a much more full featured device which will complement your multimeter very nicely. Allowing you to not only test, qualify, and identify components such as resistors, capacitors, diodes, BJTs, Mosfets, etc., but also have a simple function gen and other features.
You can find various versions of this based off of the Mega328 or GM328. Just search for GM328 or Mega328 component tester on Amazon or eBay. You will see older versions with less features and newer ones (like this one, with the graphic LCD and extra srew terminals for other features). These designs are based off an open-source project of which the english language thread is here:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
One of the main devs is a frequent poster in that thread. So you can get help, flash new firmware which add additional features, etc.
Could be, but I would think it is something in the input stage, be it a DC-blocking capacitor which now passes loads of DC or a filter cap on the input which now shorts the entire signal to ground, etc. In my experience, the buzz is usually conducted 60Hz or 120Hz (post-full-wave recitified) mains being injected into a working amplifier stage. If the power suppyl was fully dead, wouldn't you expect the amplifer stage to stop working?
Old 13th October 2017, 10:23 PM   #17
I think I may upload some photos of the insides of the boombox this weekend so maybe someone could point me in the right direction, I did try running the boombox from 12volts DC just in case it was the ac power supply that was the problem but the boombox still did not work. One other thing, previously when I took the boombox from the kitchen (where it had been on for a few hours) to clean the switches and pots, I noticed the ac transformer was very hot, almost too hot to touch, not sure if this is normal, bad ventilation? (it was quite close to the wall) or something else, the radio was crackling quite a lot before I cleaned the pots (and worked perfectly after cleaning). I will post some pics of the innards hopefully this weekend. As I say I,m only a novice so I will only be able to fix this thing if it is not too technical.
Old 13th October 2017, 10:47 PM   #18
Chetopia is offline Chetopia  United States
Yep! sounds like you have a shorted something. The power adapter should never get that hot. Unplug it and take a multimeter and check all the transistors and electrolytic capacitors for dead shorts.
Old 14th October 2017, 08:25 AM   #19
Mooly's Avatar
If the PSU is fully dead then the whole thing stops working. A zapped audio power chip is still most likely at this point (typically they also show physical damage from the overload with a split or crack in the epoxy).
The latest revelation that the PSU is now frying adds weight to the theory.
Old 14th October 2017, 04:55 PM   #20
How about the Yosoo GM328 from Amazon?, There is also a Kindle instruction book available for a couple of 's ' Using the Yosoo GM328: a guide for radio and electronics experimenters Kindle Edition ' gets good reviews?
In circuit capacitor testers advice please.Hide this!Advertise here!
Need Advice on Capacitor Replacement + Other McInRantz Solid State 17 1st March 2016 06:53 AM
Advice Needed-Capacitor Value itwashifi Solid State 10 14th February 2013 10:52 PM
capacitor advice- these caps OK? Fast Eddie D Solid State 6 15th December 2012 12:24 AM
Capacitor advice please Reference1042 Parts 28 23rd May 2012 06:04 PM
capacitor advice tomst Solid State 7 2nd April 2012 09:12 PM
