I ordered some chips and the package is MS8. It is incredibly small and the contacts are super close together. I was hoping for testing I could make some fly-out leads to my breadboard. Not going to happen. I'm looking for some junk boards at work I can hack up for soldering this teeny chip to, but no luck so far.
Anyone know of a test board or breakout board that I could use?
Use the "swipe" method to solder to the adapter pcb. Solder surface tension does the work.
Be careful not to bend the IC leads in handling.
https://www.digikey.com/product-det...pc&WT.srch=1&gclid=CN-W05-dgtUCFYRKXgodmksEjQ
http://skywired.net/blog/tutorials/how-to-solder-qfp-tssop-soic-surface-mount/
