Equipment & Tools From test equipment to hand tools
CLIO-12
CLIO-12
Old 14th August 2017, 04:38 AM   #11
secanbj is offline secanbj  Sweden
CLIO-12
Does the software version 12 work with the old hardware? (Fw-01)
Anders
Old 14th August 2017, 04:42 AM   #12
lholland is offline lholland  United States
www.audiomatica.us
lholland's Avatar
CLIO-12
On using CLIO 12 software with the FW-01 (FireWire audio interface):
It'll be a couple of weeks before I can find out if that's possible. As it is now it will not work - I tried it. Audiomatica would have to change the code a bit because CLIO 12 only looks at the USB bus when it starts up.
Old 4th September 2017, 03:41 PM   #13
Predator864 is offline Predator864  Europe
CLIO 12 will not be made available to FW-01. The modification to USB will be mandatory. Got the confirmation today
Old 4th September 2017, 06:01 PM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
CLIO-12
Unfortunate.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd November 2017, 01:53 AM   #15
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Default My CLIO 12 QC + SwitchBox V
My tools have arrived.
Old 3rd November 2017, 03:21 AM   #16
www.audiomatica.us
lholland's Avatar
CLIO-12
Originally Posted by panson_hk View Post
My tools have arrived. :)
Nice laser too! Absolutely the best way to derive T/S parameters is with a laser - eliminates the issues that can bias the result with added mass or volume techniques.
Nice to see someone has an even messier bench than I do! :)
Old 3rd November 2017, 03:37 AM   #17
panson_hk's Avatar
Yes, the laser is absolutely worth. It helps me a lot in TS as well as determining maximum-safe displacement for Rub&Buzz test.
That is the least messy area of the bench.
Old 20th February 2018, 07:46 AM   #18
ergo is offline ergo  Estonia
CLIO 12 has been on market for a while now. How are the experiences for those who have the new version of the CLIO and especially the USB version of the hardware.
Is it stable? Any issues with drivers? Any concerns on measurements repeatability (especially timing and phase)?
I'm considering sending in the FW-01 interface for USB upgrade and just wanted to query if feedback is all positive this far.
Ergo
Old 20th February 2018, 08:17 AM   #19
www.audiomatica.us
lholland's Avatar
CLIO-12
Hi Ergo:
I've sold quite a few of the CLIO 12 systems and haven't had a single customer have a problem with any of them. I also use a pair of them almost daily and they are proving just as reliable as the FireWire versions.
The upgrade to CLIO 12 is completely between Audiomatica and you, thus distributors like me are out of the loop other than telling you about it and what to do.
You send your FW-01 box alone to Audiomatica and they upgrade it to CLIO 12 including new software and make the thing perform to new specs even if it requires repairs, electrolytic cap replacements, etc. Flat rate for this is (€290). They will send you an invoice that adds return shipping to that cost.
Once you pay the invoice, they use DHL and you’ll see it about 3 days later. Takes a week or two to do the work once they get your box. If you happen to use the QC version, the upgrade is (€450) plus return shipping.
Here’s the RMA form to fill out and include with your shipment:
http://audiomatica.us/docs/support/RMA.pdf
It would also be a good idea to forward it along with tracking to Audiomatica to give them a head’s up to be looking for your shipment (info@audiomatica.com).
Old 20th February 2018, 08:17 AM   #20
panson_hk's Avatar
I have been using the USB CLIO12 (QC version with the amp/SW box) for months. The USB interface is solid. No issue has been encountered.
The only issue is changing output level during output enabled. A bump is generated instead of smooth and clean ramp up or down. I guess this happens in previous versions too.
CLIO-12Hide this!Advertise here!
Clio Lite Hylle Equipment & Tools 2 8th August 2016 07:01 PM
CLIO Pocket, CLIO or LCR meter h3ndrix Equipment & Tools 20 22nd May 2016 02:19 PM
Opamps for servos in tube amps - Christmas gift from LT, 12-12-12! Wavebourn Tubes / Valves 16 9th July 2014 04:42 AM
Any other Clio users? tipo1000 Multi-Way 14 23rd November 2010 01:04 PM
