Equipment & Tools From test equipment to hand tools
Got Focusrite Scarlett 2i2 (2nd gen) for measurements. What's next?
Old 22nd January 2017, 11:43 PM   #11
cwtim01 is online now cwtim01  Hong Kong
cwtim01's Avatar
Agree.
On the other hand, at -3dBFS level, a THD of 0.0005% (-106dB) seems not so bad, even for a good sound card. The output with the OPA1622 has a THD of 0.0004% (-108dB), so better but not by far, and THD+N are about the same.
Old 24th January 2017, 07:23 PM   #12
OlegSh is offline OlegSh
I agree that looking at the numbers the difference is minor but looking at the difference in terms of present/absent harmonics above the noise floor is encouraging. I'll try to further amplify the output to reach higher absolute levels and see if it brings further improvements.
Since it is now clear that the problem is with the output level, the next question is which parts are really responsible for the THD rise: are these the output op-amps or the D/A chip itself? I guess there is no easy way to test it without swapping the op-amps. I am fine to experiment with my unit but I have no idea how to open it. The 1st generation interface has screws at the back and TRS sockets have fixing nuts but the new unit has no visible screws or nuts to start with. Does anybody have an idea where to start opening?
Old 25th January 2017, 12:00 AM   #13
cwtim01's Avatar
Have fun searching the sweat spot with the right opamp.
In my case with my own sound card, the sweat spot requires a specific output level and input level, as both the generator and the ADC are contributing to the THD, so there is an optimal compromise.
Old 25th January 2017, 12:05 AM   #14
peufeu is offline peufeu  France
Subscribing, because I'm interested in a photo of the board inside this soundcard.
Old 25th January 2017, 07:22 AM   #15
Your result is spectacular. What sound card are you using if I may ask?
My Focusrite 2i2 showed its best when generator out is set to -16dBFS (around 0.185 Vrms) and input gain is increased to -16dBFS(it's 0dBFS is at around 14Vrms). Even then the THD I get is around 0.00029 %.
I also researched a little more about the AD/DA chip CS4272 (which people claim is inside) and indeed it might be the DAC which is responsible for the THD limit.
Anyways, I would be interested to look inside of my unit but as I wrote earlier, I have no idea how to open it
Old 25th January 2017, 07:35 AM   #16
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Hi Oleg, I found with the Focusrite 2i2 first gen that it is important to output to a balanced input to get good distortion performance, for input from SE source do not tie ring to sleeve just connect tip and ring.
I made up a circuit on breadboard using a couple of LM4562's to covert the balanced output to SE and that helped a lot.
The way to tell if it is necessary is to do a loopback with full balanced TRS cables and then do another loopback with cables that are either TS to TS. ie single ended output to single ended input. If the performance drops substantially then you ideally need both balanced to SE for output and SE to balanced for input, though as I said doing TS on the input with the balanced to SE on the output worked quite well for me.
Tony.
edit: attached the circuit I did for the balanced to unbalanced 0.1% resistors advised. This certainly helped with the gen1 2i2 it may not be necessary with the gen2...
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 25th January 2017 at 07:47 AM. Reason: add pic of balanced to unbalanced circuit
Old 25th January 2017, 07:44 AM   #17
Thanks a lot Tony! I'll resolder the connectors since I recently made a couple of balanced to SE cables to use with the 2i2 interface and, indeed, tied ring to sleeve... I also noticed significant amount of mains harmonics if using my bal-SE cables, so I'll definitely give your suggestion a try. Going all balanced is another possibility.
Old 25th January 2017, 07:52 AM   #18
just another
wintermute's Avatar
It seems like the correct thing to do but certainly on the gen1 it drops the performance substantially!
I used 12V SLA batteries for the powersupply on the balanced to unbalanced converter, note that the other advantage is it doubles the output magnitude, so effectively 6db more signal
Tony.
Some of my photos
Old 25th January 2017, 08:00 AM   #19
I think gen 2 is not much different from gen 1, except that there is no obvious way to open the unit anymore
6dB extra is always a good thing I have an assembled low noise PSU, a bunch of quality op-amps and suitable small PCBs (see my signature), so I'm nearly ready to try bal-SE and SE-bal route. I've also started putting together an attenuator for the 2i2 input, so all these bal-SE/SE-bal can go in there.
Old 25th January 2017, 09:01 AM   #20
just another
wintermute's Avatar
Note I did put 100nf decoupling caps on the opamps in the real world implementation
One difference looking at your graphs is the noise floor. definitely lower than my gen1. Below are the first measurements I took (not optimized) comparing balanced loopback with SE loopback. As you can see the distortion goes through the roof with the SE.
Also attached is measurement made with the balanced to SE circuit with with se to TR cable (third pic) you can see the improvement! Note that the third one was done with different levels probably after I had more idea what I was doing Unfortunately I can't find a straight balanced loopback done at the same time as the third pic, but the fourth one is probably more representative of the real performance...
Tony.
Some of my photos
Got Focusrite Scarlett 2i2 (2nd gen) for measurements. What's next?Hide this!Advertise here!
2nd gen 225hcca missing parts JBigDog Car Audio 5 15th September 2014 10:30 PM
Alpair 10M Gen. 3 on/off axis measurements spekr Full Range 18 4th August 2014 04:26 AM
CHR-70 Gen 2 vs Gen 3 mt490 Full Range 21 4th April 2014 01:21 PM
[IDEA] Focusrite Scarlett 2i2 hack forart.eu Digital Source 1 25th June 2013 05:22 PM
PUNCH 45 2ND GEN NON HD seankane Car Audio 4 22nd November 2011 01:57 AM
