Equipment & Tools From test equipment to hand tools
Autoranger for soundcards
Old 13th November 2017, 09:41 PM   #401
BlacK_Chicken is offline BlacK_Chicken  Germany
Ok, after having a glance at the AD536 datasheet I suspect this beeing a settling time issue. If settling time is higher than expected, the output voltage lags behind and the PIC ranges down.
Attached a scope-screenshot of PIN1@AD536 (blue) and PIN24@PIC (red). Input signal 1Vrms/1.2kHz. One can clearly see, at which thresholds the PIC chooses to range up or down. Are the treshold-values ok?
The postfilter: C16 is populated, C13 is not. ok?
Old 14th November 2017, 06:26 AM   #402
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
B_C, just for my understanding, it is only with say 1V input? If you turn up or turn down the input level, does it 'move through' the cycling going to a higher or lower att setting?
If you can move through it, it points to a specific resitor or relay, if not it points to a system issue.
Your last comment about probing the AD536 point to a possible issue with C16 or C20, see attached. Can you verify correct connection, to exclude a PCB trace break somewhere?
Edit: didn't see your last post until now. We had the same thought ;-)
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 14th November 2017, 06:58 PM   #403
Actually it is most recognisable and asolutely reproducable at 1,0 Vrms but it happens at all fast transient input level changes -> as long, as I turn the level knob of my generator fast enough it loops at almost any level.
This again points me to the settling time issue. Thanks for the schematic, I'll double check tonight.
Old 14th November 2017, 07:21 PM   #404
Seems ok. I could exchange C16 and C20 with new caps, but I am not sure if this really helps since a wrong part-value is very unlikely.
Old 14th November 2017, 07:50 PM   #405
jan.didden's Avatar
How large are the excursions? Only + and - 4dB or are they different depending on where, levelwise, it happens?
Jan
Old 14th November 2017, 08:06 PM   #406
Yes, they are differently.
For instance. Just now I turned the AR on with 0,4634Vrms/1,227kHz at the input and it cycles infinitely between +12dB and 0dB.
Turning up to 1.53Vrms it cycles between -8dB and 0dB.
Another turn on the level knob of my generator gives 2.40Vrms and the AR is still cycling between -12dB and -4dB.
Old 14th November 2017, 11:13 PM   #407
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Does it finally settle to the correct setting?
Hear the real thing!
Old 15th November 2017, 07:24 AM   #408
jan.didden's Avatar
B_C,
The only thing I can think of right now is that the averaging cap is not connected at one side.
If you exclude that, I propose you send me the atten board and I check it out here and fix as required. Free of charge of course. Otherwisw we could at this a this Christmas ;-)
Let me know if the cap fixes it, if not I send you my shipping address via PM.
Jan
Old 15th November 2017, 07:26 AM   #409
jan.didden's Avatar
Some people have asked for the control codes so they can use the settings info externally. Here they are; I will also post them at the website.
You can simply use a longer flatcable that extends outward and tap off the relevant pins.
Jan
Old 15th November 2017, 06:28 PM   #410
B_C,
Jan
Thanks a lot for the offer. I hope this is not necessary. I am pretty sure now, it must be either the Average-Cap or the Post-Filter. I have some 0805/1206 caps here to test and while the unit is dis-assembled I can double-check the connections of C16 and C20.
Autoranger for soundcardsHide this!Advertise here!
Using 2 soundcards merlinx76 PC Based 1 1st April 2011 07:46 PM
Best audiophile Soundcards ostripper Digital Source 3 18th August 2008 02:51 PM
soundcards exurbia Digital Source 10 13th August 2008 05:06 AM
Soundcards JoeBob Digital Source 21 22nd January 2002 07:16 AM
