Equipment & Tools From test equipment to hand tools
Autoranger for soundcards
Old 1st November 2017, 09:10 AM   #381
OlegSh is offline OlegSh
Yesterday evening I have finally assembled my autoranger (except C6). Looking at the calibration instruction I realized that I have no wideband AC RMS voltmeter at hands (just a regular DMM) but I have a Rigol DS1054Z o-scope. I guess o-scope should be accurate enough for measuring AC levels or I really need a dedicated AC voltmeter for calibration?
Oleg
Old 1st November 2017, 09:17 AM   #382
jcga is offline jcga  France
Jan,
Originally Posted by jan.didden View Post
Oleg, yes indeed. You were also right about C1, C8 being part of the atten board, not the control board.
All corrected, thanks for the heads-up.
Jan
minor but you should correct the quantity also... 1 for C10, 1 for C6
Best
JC
Old 1st November 2017, 12:16 PM   #383
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Arrghh...
Done
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 6th November 2017, 06:47 AM   #384
ergo is offline ergo  Estonia
I've finished my build as well. Working nice!
I added some pictures too with power supply wiring done with red(+)/black(gnd)/blue(-), so perhaps of help for some who's yet to do the build. Also marked the C27 where pinout needs the use of outer holes olny and the latest change of C6->360pF
Old 6th November 2017, 06:51 AM   #385
jan.didden's Avatar
Looking good Ergo! Thanks for the pics.
Jan
Old 6th November 2017, 01:42 PM   #386
anatech is offline anatech  Canada
anatech's Avatar
That does look pretty sharp!
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 8th November 2017, 09:25 PM   #387
BlacK_Chicken is offline BlacK_Chicken  Germany
Dear Jan,
the PICs arrived a week ago. Thank you very much for the generous support.
My AR is currently disassembled because I have troubles sourcing the NP0 capacitors. Now C6 has changed and I have nothing comparable in stock. At work: also nothing.
Can I test your software without C10/C6 or with 510pF?
Best regards
Old 9th November 2017, 05:33 AM   #388
I used 2x180pF in parallel for C6. That was easier to find.
As far as I've understood all these caps are frequency response related. So you should be able to get the device operational also with slight differing values.
As a note - at first power on you probably will not see anything on LCD... but as documentation says this is due to contrast being way off and needing adjustment. I had missed that at first in the manual and of course got a bit worried that something is wrong...
Ergo
Old 9th November 2017, 08:02 AM   #389
FdW is offline FdW  Netherlands
FdW's Avatar
I used 330p + 33p, worked fine
Old 12th November 2017, 01:44 PM   #390
I finally found a solution for C6 made out of six 0805 in series and parallel connection Time to recal. and test!
Autoranger for soundcardsHide this!Advertise here!
Using 2 soundcards merlinx76 PC Based 1 1st April 2011 07:46 PM
Best audiophile Soundcards ostripper Digital Source 3 18th August 2008 02:51 PM
soundcards exurbia Digital Source 10 13th August 2008 05:06 AM
Soundcards JoeBob Digital Source 21 22nd January 2002 07:16 AM
