Equipment & Tools From test equipment to hand tools
Autoranger for soundcards
Old 26th October 2016, 01:46 PM   #21
mroether is offline mroether  Germany
Hi Jan,
are there any autoranger news?
Old 26th October 2016, 02:05 PM   #22
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Yes, there is. One of the last issues was whether to AC-couple the outputs or not. In the single ended input mode, there is a DC source imbalance between the input channels due to a measure taken to suppress noise from the unused channel. I just did some measurements to compare different opamps to find the best one for low offset AND low distortion. Guido Tent kindly allowed me to spend some time on their AP2722.
See attached.
Unfortunately, the only real conclusion seems to be we need a better AP
Or - why did I sell my distortion magnifier...?
OTOH, both the LM4562 (LME49720) and the OPA2134 seem to do well. (I have another test with the OPA627 that also comes out quite well but that adds $ 50 to the BOM....).
Other than this last issue, everyting is basically done. I still have some work to do to finalize the switcher Kickstarter but next up is the AR.
Jan
File Type: pdf 1V 1k Viktor & via OPA627 & loopback & OPA2134 0dB.pdf (36.6 KB, 148 views)
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 26th October 2016, 02:50 PM   #23
kevinkr's Avatar
Hmm, looks like I might need to buy one of these. Following..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th November 2016, 07:13 PM   #24
jan.didden's Avatar
The autoranger development and testing is done. I am putting together 3 autorangers for beta testing by other people. If it all pans out I intend to do a Kickstarter project, but that will be very end of the year.
I'll be updating https://linearaudio.nl/la-autoranger in the next week.
Thanks for the interest!
Jan
Old 7th November 2016, 12:46 PM   #25
bremusound is offline bremusound
Jan
Great work.
I'm living in the EU and have a QA401, if you still need a beta tester
Old 18th November 2016, 02:27 AM   #26
DualTriode is online now DualTriode  United States
Smile Cable?
Yes the SE input is RCA, the Bal input is a combo XLR/TRS. The outputs (SE and Bal) are TRS.
That fits best with most sources and soundcards.
Jan
Hello,
Assuming that this AutoRanger will connect to the current version of the QA401 Analyzer, I am trying to conger up how a set of cables will be configured.
The output of the AR is SE and Bal made with a TRS. The input of the QA401 is also SE and Bal. I presume that optimal performance including noise will be balanced. For balanced operation I am picturing a DIY cable with a TRS on one end and on the other end a pair of male BNCís.
DT
Old 18th November 2016, 04:03 AM   #27
1audio is offline 1audio  United States
I'm not sure you need the autoranger with a QA401. It has similar functionality built in. The only limit is max voltage at 20V RMS. You could make a dummy load with built in divider and make that 200V equivalent and never worry about range, plus get the signal to the most accurate, lowest distortion part of the range.
The autoranger is appropriate for the QA400 or a soundcard where the input limits are more circumscribed.
Demian Martin
Product Design Services
Old 18th November 2016, 06:20 AM   #28
Default Noise-Floor
Hello,
How much do you need to spend for fun? The QA401 looks to be plenty useful as is.
The Autoranger looks to be a nice piece of equipment as well. The QA401 has a single 20db attenuator. The AR has a series of 4db steps of attenuation for high level inputs with the goal of maintaining about 1 volt output. I like the idea of using the dbV scale on a FFT plot. With one volt input to the QA401 that 1 volt 1st Harmonic will be very near 0 dbV.
For lower level inputs the AR will boost the signal, again in an effort to output about 1 volt. This amplification of a low level signal effectively lowers the noise floor and increases the sensitivity of the QA401. Check this out.
QuantAsylum Home Page
DT
Old 18th November 2016, 02:33 PM   #29
jan.didden's Avatar
To wet your appetite, here is an input-output sweep of the autoranger with an input of 0 to 5V. and a sweep from 0 to 100V.
Jan
Old 18th November 2016, 02:36 PM   #30
anatech is offline anatech  Canada
anatech's Avatar
Hi Jan,
Looking good!
-Chris
"Just because you can, doesn't mean you should" © my Wife
Autoranger for soundcardsHide this!Advertise here!
Using 2 soundcards merlinx76 PC Based 1 1st April 2011 07:46 PM
Best audiophile Soundcards ostripper Digital Source 3 18th August 2008 02:51 PM
soundcards exurbia Digital Source 10 13th August 2008 05:06 AM
Soundcards JoeBob Digital Source 21 22nd January 2002 07:16 AM
