Equipment & Tools From test equipment to hand tools
Measuring Amp output V and I
Old 30th October 2015, 09:23 AM   #1
nareshn is offline nareshn  India
Default Measuring Amp output V and I
Used a true rms meter at AC setting to measure o/p voltage of a amp ....the reading is only in mV when the loudspkr is working?
Is it because the meter is limited in freq ?
Also plan to use a true rms clamp meter to measure the output current into the loudspkr? not sure if this will work either ?
Any pointers to existing threads appreciated.
Old 30th October 2015, 09:41 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Play a 1kHZ tone, measure the AC voltage across the loudspeaker. P = V / I.
You know V. You know R. You can work out I as I = V / R. You now know P.
P is in Watts
V is in Volts
I is in Amps.
R is in Ohms.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 30th October 2015, 10:42 AM   #3
DF96 is offline DF96  England
For most speakers in most rooms playing music at 'normal' volume levels (i.e. much lower than 'live' levels) the voltage will be small.
Old 30th October 2015, 11:05 AM   #4
R.I.P.
Indeed, average levels around 100mVac are quite common.
You need to send a known, measured, test signal into the input and measure the output.
Pano has a test to do exactly that and gives the file to record to a CDR to provide the test signal.
And a DVD player can read and send the correct test signal.
regards Andrew T.
Old 30th October 2015, 11:20 AM   #5
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
with speakers, power is simply not the same as with a dummy load resistor...
a couple of months back we confirmed a Crown clone amp of 1kw (FTC) output into an 8ohm dummy load....
using a kill-a-watt device, with music playing into our speakers at chest pounding and ear splitting volumes, power draw from the mains was l little over 200 watts...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 30th October 2015, 12:11 PM   #6
Pan is offline Pan  Sweden
Due to the reactive nature of a loudspeaker you can not measure Vrms and Irms only to arrive at consumed power, you need to include phase angle as well.
Also, naturally, a 1kW amp playing nice music will have average power much less than 1kW unless you clip the amp like crazy. Music is normally (hopefully) a dynamic signal. Dynamic range may be 10-20dB (average to peak) for most music.
Old 30th October 2015, 02:48 PM   #7
http://www.diyaudio.com/forums/multi...kers-need.html
Does the spkr need to connected when the test tone runs.
The spkr i have are 4Ohms .
Old 30th October 2015, 03:08 PM   #8
R.I.P.
You need to set the vol pot with the speakers connected. After that you don't need the speakers.
But you are only trying to measure the output with a test tone input. You don't need speakers for that.
You need an amplifier that is 4ohms capable.
regards Andrew T.
Old 30th October 2015, 04:41 PM   #9
gdan is offline gdan  Greece
Maybe you are interested on this:
http://www.diyaudio.com/forums/equip...-detector.html
regards
George
Old 1st November 2015, 10:22 AM   #10
audiomik is offline audiomik  United Kingdom
If you have a look at this thread on Speakerplans, the measurement method used should do what you are looking for as well as provide you with additional information: Power Factors for 'Speakers - Speakerplans.com Forums - Page 1 Mik
Measuring Amp output V and IHide this!Advertise here!
Measuring amp output power fragman56 Tubes / Valves 24 20th November 2017 12:49 PM
Measuring amp output......how to exactly? withavee Equipment & Tools 41 16th July 2015 06:47 AM
Measuring Power Amp Output Impedance AndrewT Solid State 18 11th April 2014 02:10 PM
Measuring Current Output of an Amp Drew Solid State 10 28th October 2003 04:26 AM
measuring amp output voltage emarald Solid State 1 5th April 2003 01:29 PM
