Equipment & Tools From test equipment to hand tools
DIY Audio Analyzer with AK5397/AK5394A and AK4490
Old 29th July 2015, 06:27 PM   #11
JensH is online now JensH  Denmark
I don't think it makes sense to sell bare PCB's in this case.
Once the performance has been verified to be OK, it is time to look at the next steps. Assembled boards is definitely a possibility. Perhaps even complete units, but that is still TBD.
Old 29th July 2015, 06:59 PM   #12
soekris is offline soekris  Denmark
Don't know your capabilities or your you plans.... If you don't already have any production lined up I could take care of that, putting them into my pipeline, I'm used to procurement and production in low to medium volume and at low cost.... As I said, I was already already planning doing something very close to yours....
Søren
Old 29th July 2015, 07:26 PM   #13
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
I'd love to see this happening. Color me interested.
Gravity - Making the G since 13.7 billion B.C.
Old 29th July 2015, 09:11 PM   #14
Tazzz is offline Tazzz
750 parts is manageable IMHO Its even worse If the cheap house mounts the wrong parts on some position.
Old 29th July 2015, 09:33 PM   #15
No, then you go down to them and say: You mounted the wrong parts, please replace them with the correct ones, easy for them as they normally have the right tools....
I actually have some prototype PCB's and parts for a power amp laying here, with just 157 smd parts and none smaller than 0805. Planned to hand mount those, but after a couple of years they're still laying here....
Søren
Old 30th July 2015, 02:30 AM   #16
skidave is offline skidave  United States
skidave's Avatar
I'm excited to see your results. Looks like good work so far!
Old 30th July 2015, 04:55 AM   #17
Frex is offline Frex  France
That seem very interesting !It's a big work.
Any possibility to view schematics ?
About AK5397 ADC, did you have already purchase it to make performance evaluations ?
Frex
Old 30th July 2015, 05:15 AM   #18
Schematics? Maybe later.
No, I have not tested the AK5397. This will also work as a test PCB for the AK5397. If the performance is not good enough, I can easily go back to the AK5394A. This would sacrifice some dynamic range and the possibility to use high sample rates, but if the distortion is significantly lower with the AK5384A then it could be worth doing.
Old 2nd August 2015, 11:39 AM   #19
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Soekris,
I think you might have a niche market here. You would also be providing a much
needed service. As we DIYers are growing older, our eyes, patience, and coordination are also becoming challenged as parts are growing smaller and component layout on Surface Mount Boards is becoming difficult.
I would appreciate viewing some pics of your companies shop or yours
and some of the products/boards they've procuded.
With SMT manual layout one sneeze, one startle, one slip, and it can take more
than Sherlock Holmes to locate a part wedged on a wall molding or picture
frame, or between the weave of a carpet.
-- Sync
Old 8th August 2015, 07:35 PM   #20
I finished mounting the PCB yesterday. I have attached a picture of the assembled PCB.
Today I have started testing the performance.
The outputs look promising. I have measured the THD with a Panasonic VP-7722A. At 1kHz 0dBFS I get -104dB. The data sheet says -112 so there is still room for improvement. I get the lowest distortion at -11dBFS, where I measured a THD of -122dB. Measurements were done at 48kHz sampling.
On the input there is still some work to do. I have got signals through, but there is a high noise level on one channel and a high distortion on the other one. I need to investigate this further.
DIY Audio Analyzer with AK5397/AK5394A and AK4490Hide this!Advertise here!
New AKM Stereo ADC AK5397 announced JensH Digital Source 20 24th December 2014 12:05 PM
New AKM Stereo ADC AK5397 ??? HpW Equipment & Tools 6 16th May 2014 04:26 PM
NTi Audio XL2 Handheld Audio Analyzer Fredenando Equipment & Tools 0 18th April 2010 03:04 AM
AKM AK5394a TobWen Digital Source 41 31st December 2003 06:18 PM
